Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 07-30-2005, 11:08 AM
Tinnie Tinnie is offline
Tranny problems
Have a 1997 Aerostar 3.0L with a 4R44E transmission. Have to start driving in 2nd and manually shift to 3rd after 20km drives no prob and goes into OD. Could it be a module or something small like it needs a fluid and filter change. I was told I needed a new tranny ($2500) from a guy who has not even looked at it yet. Hoping for suggestions everything runs to smooth.
Old 08-02-2005, 10:26 PM
lilvinny lilvinny is offline
sounds like a bad trans do you have man1 if not 2500.00
Old 08-03-2005, 03:19 PM
Re: Tranny problems
Yes I do have man1 everything works except auto shift from 2nd to drive.
Old 08-12-2006, 05:23 PM
Dagoberto Dagoberto is offline
Re: Tranny problems
might want to try using an oil additive, recomend lucas, My transmission was missing, here in Mexico they'll "reconstruir" I don't know how to say that in english, for $650.00 us dlls. (overhaul?) But first I tried Using an additive, I've already put 3000 miles on it and it's running great.
Old 08-12-2006, 06:45 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Tranny problems
The proper procedure to test it is to get a good repair shop to put it on a transmission capable scanner and see what is going on.
And make sure who ever checks it knows what they are doing or is certified in transmission repair.
Avoid transmission chain shops because they are replace transmission happie.
Lot of computer stuff on it and also a engine or engine sensor problem can mess it up.
May be simple fix or a hole transmission.
But say no to additives.
Also a good time to check fluid and filter.
MT
MT
