Old 07-30-2005, 12:24 AM
bcreverend's Avatar
bcreverend bcreverend is offline
Question is this normal?
i just got my car back from a napa shop where i had my new eibachs put on and as i'm driving home i notice that my car is running at about 210 degrees despite having a 180 degree stat. i can't remember the temps ever getting that high before, and i have to run the heater to get the temps back down to the 180 range. i know its not anywhere near the red line of 260 but my dads gpgt just cracked the engine block we think because of over heating so i'm a lil paranoid. i just got an ses light as well but i think thats just from stomping on the gas...what do you guys think the trouble could be?
silver 99 grand prix gtp with Intense standard pcm, 3.4 intense modular pulley, oversized supercharger idler pulley, zzp underdrive water pulley, zzp overdrive alternator pulley, tps enhancer, open cone filter, thrasher shift kit, strut tower bar, eibach springs, autolite spark plugs, 180 degree t-stat, throttle body spacer, flowmaster catback w/U-bend delete, Rear O2 simulator, silvania headlights, xenon foglights, 40 cp reverse lights, and a custom 600 watt audio with cd changer.
Old 08-13-2005, 10:34 AM
durrel durrel is offline
Send a message via AIM to durrel Send a message via Yahoo to durrel
Re: is this normal?
I have a 1990 gp, it usually run about 190 to 210 depending on weather conditions outside and whether the a/c is on or not. But I would double check to make sure the fluid level in the radiator and the resevior is were they need to be with antifreeze/coolant mixture, NEVER straight water
Old 08-13-2005, 12:40 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: is this normal?
did the overheating occur after the lowering kit was installed? They seem like unrelated issues. I would check for a possible intake leak, common on 97-99 3800 vin-k engines. it may be a co-incidence that it happened after the lowering kit was installed
Old 08-13-2005, 01:39 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: is this normal?
Since you lowered the car you may have an airflow problem to the radiator. There was another thread on the forum where a member was having trouble with the car running hot. His problem turned out to be a missing air deflector. If you removed yours then that could be causing less air to flow to the radiator and is increasing the temperature. 210 degrees is not that hot anyway so I wouldn't worry too much about it at this point.
Old 08-13-2005, 03:06 PM
richtazz's Avatar
Re: is this normal?
Nice call GTP. I didn't think of that one, that the lowering company may have removed the deflector to keep it from scraping.
Old 08-13-2005, 05:06 PM
bcreverend's Avatar
Re: is this normal?
thanks guys for getting back to me. i'll check on those things
