Old 07-29-2005, 10:40 PM
blazerTx blazerTx is offline
Unhappy blower motor doesn't work properly
Hello everybody,
blazer 4X4, 4.3L. 1995
Sometimes the blower motor doesn't work. I have changed the motor for a new one.I found a drop voltaje in the conector. The vaccum system is working verywell.I have also changed the blower switch. But the problem is still there.
I checked the voltaje in the conector, High 12V, medium and low 14.2V
I reviewed the fuses, it looks ok.
The front wiper works every other day.
Do you think that the problem could be the ignition switch?., or a relay located in the 'heater box'
Ktallman had the same problem. He mentioned that could be the ignition switch. But I want to make sure. (the ignition switch is $$$$ expensive)
thank you a lot,
I appreciate it.
Old 07-31-2005, 08:29 PM
Ktallman Ktallman is offline
Re: blower motor doesn't work properly
I finally took my Blazer to the dealer that I purchased it from. They ran the codes and found nothing. They then cleaned all the connections. Everything is working fine so far.
P.S. I took it to a Dodge Dealer as my local Chevy dealer sucks as experienced in the past.
Ktallman
Old 07-31-2005, 09:01 PM
I forgot to mention that the bill was less then $70.
Old 07-31-2005, 11:52 PM
Hi Ktallman,
I finally found the problem. The f**** relay.The relay is located under the hood, right above the distributor cap.
Thanks a lot .
