Old 07-29-2005, 10:39 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
electric oil psi gauge install
started installin my autometer oil psi gauge(electronic) and ran into a few questions.
1) do you guys recommend removing the stock sending unit and replacing it with the autometer one or is it better to use one of the spare ports? and if so are all the ports near the stock sender usable?
2) wheres the best place to ground the guage? instructions say "groudn near the sender on an engine groud"
thanks for any help
Old 07-30-2005, 07:19 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: electric oil psi gauge install
for the sender you should just buy a tee so that you can have both of them mounted in the same port. if you just unplug the stock one your oil light will stay on all the time. for the ground just ground it to any bolt going into the block
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 07-30-2005, 10:50 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Actually, when you unplug the stock sender, the light doesnt come on at all.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-30-2005, 11:43 AM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Your gauge just drops :-)
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 07-30-2005, 11:57 AM
k i didnt think 2g's had a guage i thought they just had a warning light
-1stGenRocks-
Old 07-30-2005, 12:25 PM
david-b's Avatar
Dave is THAT guy
It is just a light. DSMODDER has a 97 eclipse. Doesnt the turbo models have an oil gauge? I know they have a sender unit right above the oil filter. If you unplug that, your gauge will not work. If you get an aftermarket one, take out the stock pieces, and use the new sender.
75 Monte Carlo
Old 07-30-2005, 01:21 PM
Turbo model has a gauge
2002 VW Jetta 1.8T
Old 07-30-2005, 08:17 PM
yes 2gs have a oil gauge and warning light. i was thinking of retaining the warning light and using the aftermarket gauge just incase im not paying attention for some odd reason and the stock sender shows the light...
anyway has anybody used one of the spare ports in the oil filter housing for this or should i just use a t fitting???
also wheres the best place to ground the gauge.
Old 07-30-2005, 08:33 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
i went through the install a few months ago. there is my thread. and a pic of it installed. i didn't use enough Tephlon tape. it leaks a little.
http://www.automotiveforums.com/vbul...d.php?t=400601
DSM geek
Old 07-31-2005, 01:29 AM
kjewer1 kjewer1 is offline
AF - Advisor
I like to keep the light and replace the guage. There is absolutely no point in keeping the stock guage, there are no numbers on it, rendering it completely and utterly useless. Thanks Mitsu. Keep the light just in case. On the 2G, the front sender is the light, the rear is the guage.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-31-2005, 12:44 PM
thanks thats what i needed to know. but where is the best place to ground the gauge????
Old 07-31-2005, 02:08 PM
any bolt that you can get to easily and fit a wire ring terminal around. it really doesnt matter
-1stGenRocks-
