Old 07-29-2005, 10:13 PM
xaviar2277 xaviar2277 is offline
Unhappy 96 Blazer Bad idle
I have a 1996 Chevy Blazer 4.3 Vortec I just bought this vehicle I have replaced all the plugc AC Delco Platinum. I checked the old ones they were all uniform in color. The reason I replaced them It has a rough Idle . Thought maybe a miss fire. Also the dealer replaced the fuel pump before I bought it. Since the plugs did not fix the problem I removed the Throttle body and cleaned all the carbon off w/ a toothbrush. But still did not fix problem. My next guess would be the MAF. But the reason I am guessing, is because the check engine light is not on. But I do know that it works because if I unplug the MAF it comes on But the engine runs the same pluged in or not????? Thats the reason I'm thinking MAF because there is no change in condition of idle when I unplug it. Any help would be appreciated thanks
Old 07-29-2005, 10:24 PM
DINO55's Avatar
DINO55 DINO55 is offline
Re: 96 Blazer Bad idle
Did you also change the Dist cap and rotor along with the spark plugs?
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 07-29-2005, 10:33 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Distributor cap and rotor
PCV valve
Air filter
Fuel filter
MAF cleaning
Vacuum leak
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-29-2005, 10:48 PM
DINO55's Avatar
Also check the spark plug wires at night time with engine running. Look for ARCING. Leaky wires will make your engine Idle poorly. How many miles on the clock?
Old 07-29-2005, 10:53 PM
Blazer bad idle
When I say rough I mean likea missfire I would swear thats what it is. But no I did not replace the wires or cap and rotor. I will check tonight for arcs but I do not here it arcing. It seems that it gets worse the longer you drive. Today @ my apty complex It idled @ 500 rpm but when you gave it gas nothing would happen It just sat there. And still no SES light??????
Old 07-30-2005, 12:22 AM
BlazerLT's Avatar
AF -Advisor
Cap and rotor probably will fix it.
Be replace everything I listed in my previous reply.
Old 07-30-2005, 02:10 AM
I will try
I will try the cap and rotor tomorow I will let you know thanks
