Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 07-29-2005, 09:28 PM
subject~666~ subject~666~ is offline
aside from the turbo
ok i just read somewhere that a complete turbo package is about 2900.. aside from that what else will need replaced.. is the tranny capable of handling the turbo? the exhaust? i am thinking of doin this to mine, but i have no mechanical backround and dont know crap about it but i can learn easy so any diy info would be appreciated websites or ebooks.
thanks
Old 08-02-2005, 05:39 AM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Can you please post the info on your car (year, engine, aftermarket upgrades) and what kit you looked at. I'm assuming that you looked at the kit at hahnracecraft.com. If that's the kit that your looking at then the only things I would recomend that the kit doesn't come with is a boost controller and a boost gauge. All of your stock parts (except what the kit replaces) should work for a 5-12 psi upgrade. If you want to boost higher than that then I would upgrade your pistons and replace your head bolts with something stronger. Your tranny should be fine up to 400 whp.
AF COMMUNITY GUIDELINES
Old 08-05-2005, 10:08 PM
sorry took so long painting the car atm its hell... anyways its a 96 4 cyl 5 speed manual and i have no after market upgrades what so ever its just now i have a badass paint job and the performance just needs to match it ill post pics sometime..... and yes i was looking at the hahn turbo kit, is it any good? worth the money? i m no mechanic so any info is helpful
Old 08-06-2005, 10:03 AM
TheStang00's Avatar
TheStang00 TheStang00 is offline
Re: aside from the turbo
looks to me like the kit has basically everything youll need. only things i can think of are little ones, like if your turbo is oil cooled then your gonna need a 1-1/16 in socket, and theres a little breather tube on top of the engine that your current intake connects too, your turbo one wont so you need to do sometihng with that tube. what we did was we just bought this little mini air filter at autozone and stuck it on there. looks just like a regular cone filter but its only about 2 inches long, if that.
Old 08-06-2005, 04:12 PM
ok well so would u recommend doing this to an avenger or is just a pos that isnt worth fixing??? and also if anyone would know why my car has a grinding when i shift into second gear at a high rpm it grinds ive looked for recalls but none are showing this. when i first bought my car it had a grind in reverse or 5th gear cant remember and they replaced my tranny w/ a new one, but now it has a 2nd gear grind.
Old 08-06-2005, 04:50 PM
From what I've read about the kit, it's the best kit that you can buy aftermarket for a stock system. You'll notice a huge jump in power. As for the grinding, it's your syncros for second. Those usually go out faster than the others for people who like to race. Replace the syncro and it should fix the problem.
