Old 07-29-2005, 08:01 PM
iwillflipyouout iwillflipyouout is offline
Crx b16... big problems
I just finished doing a b16a1 obdo swap into my 1991 rex... everything is wired up right and seems to be fine except for one huge problem... the motor won't rev higher than 3400 rpms... in any gear... it just dimply cuts all gas and air and i get a coughing sound....the motor kepps running... it doesnt stall or anything. but i cant do anything with a vtec motor that wont rev high enough for me to hit vtec... can anyone help me out?
Old 07-29-2005, 08:11 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
check the timing
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 07-29-2005, 09:22 PM
1990civicHB 1990civicHB is offline
Send a message via AIM to 1990civicHB
Re: Crx b16... big problems
What codes are you throwing...Your running in limp mode. I was doing the same thing for a while. It's not your timing. It has something to do with either vacume, or wiring. Make sure your knock sensor is plugged in and that plug on the back of your ITM. I put a skunk 2 on mine, and forgot to plug in the sensor on the IKE valve, and I was running in limp.
Don't forget to check your codes. Thats a dead give away.
Old 07-30-2005, 10:32 AM
I'm throwing a code 4 and a code 6
Old 07-30-2005, 01:30 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
code 4. check crank angle sensor and wiring. check continuity.
check your engine coolant temp sensor with the code 6. check wiring or change sensors.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 07-30-2005, 01:31 PM
AF - Advisor
PS:
here's some reference for ya
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
Old 07-30-2005, 09:28 PM
Re: Re: Crx b16... big problems
I am throwing a 1 and 6 in my car. Of course the o2 sensor because there is sapposed to be 2, but I am also throwing a 6. Your car will still run fine with the sensor not working. It should only effect start-up. Mine surges a little, but only until it's warm, but thats also the uberdata being gay.
The crank angle sensor is mostlikely what is causing you to run in limp. Get that fixed, and your problems should be solved, and if thats not the problem hey, atleast its not throwing a CEL anymore . Good Luck man. tell me if any of this helps.
Old 07-30-2005, 09:38 PM
skotman's Avatar
skotman skotman is offline
if the crank angle sensor itself is bad, you'll have to get a completely new (used) dizzy. i got one on ebay, but it wasn't as cheap as the guys here were saying it'd be. i had to pay about $45 total with shipping. not that bad for a major car part...
Old 08-01-2005, 05:49 AM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
OEM honda dizzy's are 900 bucks...lol!
Old 08-12-2005, 09:58 AM
Re: Re: Re: Crx b16... big problems
got the distributor thing fixed... bought a brand new one... and its still in limp mode
Old 08-12-2005, 11:09 AM
AF - Advisor
