Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-29-2005, 08:28 PM
stealth1 stealth1 is offline
starter question...
Removed battery and starter and had both tested. Both good. Hooked up push button from solionid(sp) on the starter to the battery and the car starts every time I push the button. I know I basically bypassed the ignition relay or starter relay but I don't know which one or where it is located. The repair manual was no help whatsoever on locating it. Any suggestions... Oh yea it's a 96 eclipse gst.
Old 08-03-2005, 03:15 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: starter question...
Why do you need to find the relay? It should be on the top of the relay box.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-03-2005, 08:29 AM
Found it. It was behind the radio on the hump. jumpered the relay for the starter and she fired up..... Not sure why it is there but it is.
