Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 07-29-2005, 05:48 PM
shadowowner shadowowner is offline
'92 shadow won't start
If the timing belt slips off is it possible or even likely that the timimg gets so messed up the engine won't start? This has happened and I'm looking for ideas. Thanks
Old 08-27-2005, 01:59 AM
ricebike ricebike is offline
Re: '92 shadow won't start
yes
Old 08-29-2005, 10:09 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
you could have even done serious damage to your engine, i.e. valve train. Could now have a bent valve(s) if the timing skipped a tooth.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-30-2005, 11:34 AM
Re: Re: '92 shadow won't start
not necessarily on this type of engine.
look here for the list of engines:
http://www.troublecodes.net/tbelt/chryslertb.shtml
if you got the "interference engine" (*), then you'll be in a world of hurt as quoted by the fellow member.
if you got the "freewheeling engine," then you'll be ok as far as valve-to-piston clearances. you may not get the engine running, but @ least you won't haveta rip the head off to inspect for bent valves
i personally experienced this w/ an 88 dodge k-car 2.5L... belt snapped, but i was able to put it back to service just by aligning the timing marks & installing a new one. alas, i've moved on to a nissan 240sx (mmm, timing chain)
Old 09-20-2005, 11:13 AM
SikEnCide's Avatar
SikEnCide SikEnCide is offline
Send a message via AIM to SikEnCide
if u have the 2.5 4 cly you will have no problem i had my timing belt skip a few teeth and then shred itself while i was doen 80mph.... coasted to a stop got a tow. replaced the belt and htere are no valve taps no problems.. just simple alinging for hte timing if u buy a maitnance guid it tells u everything...... only problem was i had to remove the passenger side engine mount to do so
