Old 07-29-2005, 01:24 PM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
Question Toys toys toys...
Got a new all alluminum High Performance KOYO Rad. today. I cant wait to put it in, but what do u guys think about KOYO? Also do u think it would be ok to install the new rad. and fill with water and run the car with the drain port open to fushout the cooling system?
Old 07-30-2005, 12:42 AM
BullShifter's Avatar
Re: Toys toys toys...
Aluminum rad is a waste if you dont need it.
instead of running the engine, just put a garden hose in upper/lower hoses. Flush both ends til it's clean.
Your best off flushing with the correct mix of coolant, here we use 50/50mix.
Old 08-01-2005, 08:35 AM
91CRXTC's Avatar
Well i put it in and it works, no leaks or overheating. Why not improve if u have to replace, i drive 37miles one way to get to work everyday, and the way the heat has been here it would help to keep the engine cooler especially when i have to deal with 1.5 hours of stop and go traffic. Plus the slight reduction of wieght, but why would that be better then a 15 y/o twice as heavy rad made out of plastic.
