Old 07-29-2005, 12:52 PM
rhinton rhinton is offline
Fuel Pressure issue?
Can anyone tell me about the fuel pressure in a 1996 Trans Am. Maybe that is what is giving me the bad start ups and rough idle. How can this be fixed? Without help from expensive mechanic or dealer.
I changed out the fuel injectors a while back ago and ever since then it's been giving me problems. But before that I changed out the spark plugs and wires. Used AC Delco plugs and good wires. So I don't know if that is why it is giving me a bad start up or not.
One of the mechanics I go to told me it may be a fuel pressure problem, but I don't know how to fix that or even where I can start. Any pointers?
1996 Pontiac Trans Am- 85,000 miles Black/Black leather interior, auto trans, BMR rear lower control arms, Trick Flow Air Inlet, Russell brake lines, slotted front rotors, Auburn differential 3.23 gears with bolted alum. girdle. Trying to fix my repairs now. So sad really. But with every replaced part, comes a better part!
Old 07-29-2005, 07:20 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Fuel Pressure issue?
Should be around 40 -45 PSI on start up and then drop 10 PSI once started. Good luck
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
