Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-29-2005, 12:57 PM
fiendelico fiendelico is offline
OOPS...Ran out of gas.
1991 Nissan Maxima ran out of gas. What do I need to do to get it running again? I already put more gas in the tank. If I need to prime the injectors, how do I do it?
Old 07-29-2005, 01:30 PM
94hondaacc 94hondaacc is offline
put gas in it. open and close the ignition switch to get gas to the injectors, and try to start. hopefully you didnt ruin the fuel pump, which is a very costly oops.
Old 07-30-2005, 02:34 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: OOPS...Ran out of gas.
When u turn ign, pump will start (you'll hear it). If not, check fuses. If not, take rear seat off and measure from connector the +12V. If not, repair. If voltage present, pump should turn, If not, replace.
Its also possible that filter became blocked from tank bottom soot. Replace.
When pump ok, gas will be flowing to injectors. Fuel hose near filter is stiff... Start an go!
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
