Old 07-29-2005, 11:55 AM
leadfootGTP's Avatar
leadfootGTP leadfootGTP is offline
case learn
if i got a new pcm, and had a case learn performed on it, and then modified my exhaust a week later, would i have to have the case learn performed again, or is it just a one time thing?
and
i know that the dhp pcm are programmed to work best with exhaust, air induction, smaller pulley. I have modified my air induction system, gotten a smaller pulley, and a 180 drilled tstat, but as it says above, i will not be modifying my exhaust for a week or so, in the mean time, will not having this mod actualy damage my car, or will i just not get the full result from the pcm until i have all of the modds?
[IMG][/IMG]
Old 07-29-2005, 12:05 PM
theblurr87 theblurr87 is offline
Send a message via AIM to theblurr87
Re: case learn
and
thanks Big-L wherever you are...
http://www.automotiveforums.com/vbul...ght=case+learn
hehe looks liek you only needa get a case learn done when you do that stuff.
'99 SE (l36) 125k mi.
FWI | ZZP HVTB St. 1 | WP UD Pulley | 3" DP/HF Cat/U-bend Del.
Old 07-29-2005, 12:06 PM
dmasjz45 dmasjz45 is offline
Re: case learn
and
case learn deals only with the crankshaft position. installing a new exhaust system would not need any work done to the pcm. a case learn only deals with the crankshaft position.. your car will not be damaged, the exhaust will have no effect on the pcm, so you don't have to do anything else
Old 07-29-2005, 12:08 PM
Re: Re: case learn
o0o0o beat ya 1:05 =p
Old 07-29-2005, 12:20 PM
Re: Re: Re: case learn
:'( yeah i saw that but at least i answered his question clearer :-D
Old 07-29-2005, 12:36 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: Re: Re: case learn
When I installed my DHP v1.0 PCM, I did a case learn and it is recommended by Digital Horspower and companies like Intense for optimal performance. Its a one time thing and does not need to be done again if you do other mods such as exhaust. This is true especially if you do not get your original PCM back and its exchanged.
DHP FAQS:
http://www.3800performance.com/digitalhp_faq.htm
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 07-29-2005, 02:45 PM
Re: case learn
Alright, thanks a lot guys
[IMG][/IMG]
