Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 07-29-2005, 11:53 AM
BluesCruiser BluesCruiser is offline
Help error 0411
97 jetta , 2.0 , 4 speed std. , GL
error code 0411 2nd airflow
fix = 1st circuit failure or open fuse
where is this and what does it look like ?
fix 2 = bad air pump or clogged hose
again where is pump and witch hose
inspection due
I have replaced air filter, cleaned large hose to choke (oil in hose wiped clean) checked those small plastic hose that attach to air box , they seem ok and pass air through them ok...stumped help
Old 07-29-2005, 12:10 PM
all so does the brown plastic tube from the airbox go on top position or bottom on the air box the black one come from the motor.
does it make a difference..
