Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 07-29-2005, 11:31 AM
jworm420 jworm420 is offline
Question C4 Swap ?
I have a 95 T-Bird 4.6 that i have done some motor work two and put a full flwomaster eshaust system on, well any way i guess i started to put to much power through the DOAE 4R70W and blew out second gear takeing doen the strip at norwalk.... any way ive herd a few people say that the C4 should be a direct bolt up to my bellhouseing and mount rite in with out changeing much... i know i woud have to come up with a custom linkage kit but has anybody out there swaped for a c4 and if so how hard was it ?
Old 07-29-2005, 10:52 PM
coondawg6 coondawg6 is offline
why? c4 doesnt have od and gear ratios much lower check out PERFORMANCE AUTOMATIC in gaithersburg, md. they can tell you anything you need to know about ford trans. they sell hi hp 4r70w and all you need to swap if your hearts set on it BTW i dont think a modular pattern bellhousing and an old windsor type bellhousing would be the same
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
Old 07-30-2005, 02:19 PM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
I'm with coondawg6 on this.
Even if were able to mate the C4 to your 4.6, you would still have to re-program your EEC.
The 4R70W automatic transmission can be built to handle 575 RWHP.
Here is the best write-up you will find on the 4R70W automatic transmission ....
Ford Overdrive Transmissions 101
By Ford Transmission Engineer - Jerry Wroblewski
