Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 07-29-2005, 08:05 AM
EDOG25 EDOG25 is offline
Spark plugs
Would somone please explain to me where the spark plugs are for a 2002 galant because all I can find is two of them.
Old 07-29-2005, 01:20 PM
mitsufreak04 mitsufreak04 is offline
Assuming you have a 4 cylinder, the other two plugs are actually under the coil-pack and bracket assemblies. In order to better manage the spark timing in your Galant, Mitsubishi has implemented a distributorless ignition system. This system uses a coil-over-plug ignition coil and the Engine Control Unit (ECU) to manage which spark plug fires and in what order.
To check/replace these plugs, first remove the spark plug wire and electrical connector from the coil-pack, then unscrew the coil-pack from the bracket on the cylinder head. The pack should then pull off just like a regular spark plug boot. If replacing your plugs, don't forget to use anti-seize compound on the threads and always use the correct torque! (18 ft-lbs.)
Hope this helps!
Old 08-01-2005, 03:56 AM
stangman1 stangman1 is offline
ive got a v6
Old 08-01-2005, 12:48 PM
Sorry about the confusion. The three plugs for bank 1 (rear bank in the eclipse) are actually underneath the intake plenum. You'll have to remove the intake plenum to get to the spark plug wires on the V6. I wish there were an easier way, trust me!
Here is an excellent walk through of the process.
http://home.pacbell.net/fong8/gstuff/tjc_plenum.htm
Hope this helps!
Old 01-05-2006, 04:22 PM
uscxv uscxv is offline
Re: Spark plugs
Hope this helps!
Do you have a walkthru for finding and changing the plugs on the 4 cyl?
