Old 07-29-2005, 08:35 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
rear disc swap
just wondering if the rear disc conversion will still work on the 4g4d? since i have everything at home already (minus the prop valve and one hose) but i'll be doing the swap in the winter time anyways. just wondering if it will still work and if i still use the teg e-brake cables too..
thanx
Old 07-29-2005, 10:38 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: rear disc swap
everything should bolt on, but I'm not sure about the ebrake, you may have to use one off something else that is longer, mine is off a four door teg and is only maby an inch or so longer than the factory one, so I dont know.
Old 07-29-2005, 12:09 PM
1PhatCX's Avatar
Re: rear disc swap
thanx man, the cables i have are from a 2-door integra, maybe i'll look into getting 4-door ones if they are longer, gonna have to measure things first of course
Old 07-29-2005, 12:15 PM
Forunn Daberator
Re: rear disc swap
You could probably use some from something longer like an accord if those arnt long enough.
Old 07-29-2005, 03:56 PM
1PhatCX's Avatar
Re: rear disc swap
alright, thanks alot TSC
Old 07-29-2005, 06:59 PM
crv-tec crv-tec is offline
Re: rear disc swap
Qustion: Will the e-brake cable from an accord still work on a CRX? I got the assemblys, with the teg e-brake cables, but thats about it. Still need to get rotors, bushings, pads, lines, hot tank parts, etc...
'nuff said
