Old 07-29-2005, 03:29 AM
klutz_100's Avatar
Question removing chrome question
To date I have removed chrome from parts by soaking in DOT 3/4 - it comes of fine with a toothbrush but takes a few days to get it all off.DOT3 bath is always glittery with bits of chrome plate residue.
Recently though I read about using bleach to remove chrome so I tried it out with Domestos Gel. After about 10 seconds the chrome fades away in front of me and the part is colour of original plastic. No visible residue left in the bleach.
I was so surprised at the speed that I decided to look closer and it seems to me that there is still a kind of "film" over the pieces that is probably coming form the original chroming process.
Here's my question: did the chrome just bleach the colour away or did it remove the chrome? Can I just prime over this slightly glossy film and then paint or do I need to remove that too?
Would be gratefull if other "bleachers" would share their experience with me.
Thanks in advance.
Old 07-29-2005, 04:13 AM
ZoomZoomMX-5's Avatar
Kit chrome is a two-layer process. The outer layer being the visible chrome plating and the inner layer of clear paint that is applied underneath the chrome. If that clear paint wasn't applied, the chrome would not be shiny. W/bleach you have only removed the outer layer of plating which is very thin.
Most people will tell you to remove the clear as well, but if you are painting the part and the clear isn't too thick and isn't filling in detail, I'd just leave it as-is, just use the clear as a primer and save the time it takes to completely remove the clear which can take awhile.
Only if I'm restoring chrome parts by sending them to a service to have them replated will I remove all the clear underneath.
My Fotki Album
Old 07-29-2005, 04:31 AM
klutz_100's Avatar
Re: removing chrome question
Originally Posted by ZoomZoomMX-5
Kit chrome is a two-layer process...
Thanks for that. It fits right in with what I thought.
So what do you use to remove the clear paint? DOT?
You're lucky to have access to a re-chroming service I suppose the final result really is better than kit chroming or alclad2
Old 07-30-2005, 03:16 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Oven cleaner takes the chrome and clear base off in one step, it should take the clear off too... - Mark
Old 07-30-2005, 03:35 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
try csc, leave the chrome parts in there for about an hour and everything comes off without scrubbing
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 07-31-2005, 09:27 AM
datsunfreak's Avatar
datsunfreak datsunfreak is offline
Send a message via AIM to datsunfreak
I have been using vinegar for quite a while. It seems to work very well, quite fast, and isn't nearly as caustic as some of the other methods. I don't know if it's leaving the clear film or not, as I usually paint right over the stripped part.
Old 07-31-2005, 09:33 AM
RallyRaider's Avatar
Zomby Woof
Not all companies use the clear layer under the chrome. Fujimi for instance don't. Not sure about Tamiya, Revell certainly do.
Old 07-31-2005, 09:43 AM
klutz_100's Avatar
Re: Re: removing chrome question
It's actually a Monogram Lotus Esprit US Version that I tried bleach on so I'm guessing in that case that it's a Revell in mufti (or vice versa)...
BTW this is a kit I should have tackled with more experience under my belt - talk about bad filtting!!
Old 07-31-2005, 02:03 PM
campenr.1's Avatar
campenr.1 campenr.1 is offline
oven leaner is the quick and easy way to remve chrome and all hidden underneath layers
Current and past projects:
Old 07-31-2005, 02:32 PM
badboy00z badboy00z is offline
I heard Castro Super Clean works the best for stripping paint. But I'm not sure if it will work on chrome.
Old 07-31-2005, 05:52 PM
I've used it and Simple Green to strip paint, but it didn't seem to work well on the chrome I tried.
Drive A Datsun, Then Decide.
