Tranny Swap?
Hi All
According to the build sheet, I have an A-518 tranny. Does anyone know if I can straight swap in a 727, or what I would need to do to enable that swap? The truck is a 1994 Ram 1500 4x4 with a 5.9 (360). Any help would be greatly appreciated. |
Re: Tranny Swap?
Two things come to mind that could be problematical. The first is that the bolt pattern on the new transmission may not match the one on the current transmission. The second is that I think the 94 auto transmissions are electronically controlled, so the computer may have issues with not receiving that input from the transmission.
Re: Re: Tranny Swap?
Daily Overhauls Do Get Expensive Dangerous On Days Gears Engage Dead On Day Guarantee Expires Dead Or Dying Gas Eater Department Of Defense Garbage Equipment Dodge Owners Don't Get Excited Don't Overdrive Gutless Engine Drips Oil Drops Grease Everywhere 1995 Dodge Dakota SLT 3.9 V6 1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4 |
Re: Tranny Swap?
Cool thanks for the stats.....
It will bolt in.There is one differance,the torque converter.If the transmission came off a 318,no weight on the torque conveter and a 360,a weight on the torque converter.There is a boot around the the crankshaft position sensor.Throw away that boot away.You do not want replace the crankshaft position sensor.Most transmission shops do throw away the boot away.Also check the bottom transmission line towards the radatior.Some idiotic engineer at Daimler Chrysler thought of putting a plastic checkball and it was a big mistake.The plastic checkball melts,plugs the line up and will burn up the transmission.Get rid of that plastic checkball by drilling it out,a spring should come out and blow it out very good after drilling it out.The plastic checkball is white in color.
Re: Tranny Swap?
does anyone know if i can use the od unit from a 94 1500 with a 318 on my 98 with a 318? i know i have the od button on my shifter and the 94 does not. is it the same od unit anyway? thanks in advance. SC
