Old 07-28-2005, 11:39 PM
8Birdman8 8Birdman8 is offline
3.4 crate engine to replace 2.8???
Ok i want to put it in my bird but after doing some reading it says it is only available for automatics??? Why the hell cant i use it with my 5spd?? Is there something im missing here?
Old 07-29-2005, 12:04 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: 3.4 crate engine to replace 2.8???
Um, what site exactly are you looking at? There's no problem at all with putting it on an auto or manual. Same engine, just different tranny's.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 07-29-2005, 12:56 AM
http://www.gmgoodwrench.com/perfpart...on=ce&cat=9274
Technical Notes: This is for engines with carburetors only, not released for TBI usage. This engine does not have a clutch boss on the side of the block for standard transmission application.
Old 07-29-2005, 02:09 AM
blindeyed's Avatar
eBay aDdict™
Ok well do you currently have a 2.8 or 3.1 in your bird? If so, then that engine will go in fine. The block is identical to that of the 2.8 and 3.1, so everything on those engines will transfer right over onto the 3.4. Shouldn't give you any problems. Whether or not if it's a manual or auto. Don't know why they stated it's only for auto's, that's just weird.
- Jason
Old 07-29-2005, 08:09 AM
MrPbody MrPbody is offline
AF -Advisor
Rather than buy a crater, consider finding the correct F-body block and enlist a good engine builder. You'll probably save money and get more power. Crate motors are convenient, but that's where their advantage ends.
