Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 07-28-2005, 09:31 PM
andrew_alfonso andrew_alfonso is offline
DRL module for CR-V
Hi everyone,
I would like to install a DRL module I saw on www.webelectricproducts.com for my '97 CR-V. I am planning to place the module under the dashboard, tap the connections under the steering column wiring harness and I would like to ask help from anyone to identify the color of the wires for the following :
1) Left turn Signal
2) Right turn Signal
3) Park Light
4) Ignition (when you turn the key to 'ACC', not hotwire)
This DRL module automatically switches on when you start your car, lights up your turn signal filaments and cancels the operation once turn signals are in operation, and goes back on when you're done with your signal. think it could be better than turning on the high beams of the headlight.
Has anyone already installed one in their CR-V? I would truly appreciate any feedback on this module and the info on the color of the wires.
Thank you!
