Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-28-2005, 08:52 PM
ruberpoliceman ruberpoliceman is offline
86 caprice timing issue
i have a 305 5.0 liter v8 with a quadrajet carb. I have rebuilt the carb and replaced timing chain, distributor cap, rotor,plugs,plugwires, and several other things. right now it missfires and i cant figure out why. I have set the timing and it still misfires, when i accelerate it pops back through the carb, someone suggested to me to pull the distributor out and advance it 5 degrees or so, will this work??????
more suggestions are welcome.
Old 07-29-2005, 01:52 PM
CAPRICE LIFE CAPRICE LIFE is offline
Send a message via AIM to CAPRICE LIFE
Re: 86 caprice timing issue
thats most definitely the timing...dont know how many degrees....r the plug wires on the right cylinder number?
Old 07-29-2005, 02:01 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
You do not have to pull the distributor out to set the timing; just loosen the hold-down nut and rotate it.
But get a timng light on it to set the initial timing. If you don't have one, do not guess at it. Borrow or buy one. They are handy to have, even if you just use it twice a year.
Be sure to disconnect the vacuum advance hose before setting the timing.
Also, my bet is you have 2 plug wires reversed.
Old 07-30-2005, 06:27 AM
i know how to check the timing ive done all that, the guy said something about pulling the distributor i just didnt quite catch everything he said and was wondering if anybody else knew anything about it, and no ive checked the wires over a million times, Now that i think about it when i had the timing light on the #1 cylinder or any cylinder realy from time to time it just wouldnt spark ( no light flashed ) and also the harmonic balancer jumped back and forth (the mark on it) what does this mean???
Old 08-06-2005, 01:51 AM
RamAir81 RamAir81 is offline
Go back and check your valves adjustment you could have one to tight.
Old 08-06-2005, 02:57 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
its real hard to say without being there and seeing hearing it but have you pulled distributor at all ? has it ever ran right since youve owned it?
to adjust rocker nuts correctly the lifter must be all way down in its bore in the engine block,
i would probably make sure rockers are adjusted correctly first and also put engine at TDC #1 position(pull #1 spark plug which is the driver side first one and bump engine over whiel feeling for air rushing out of spark plug hole when are turnig engine, then stop and go real slow with it til the timing mark on balancer is on the round tube thingy on the timing plate on the timing cover, this is TDC #1) now your distributor rotor is supposed to be pointing at the second spark plug cap wire tower clockwise away from where wires plug into the cap, this is the stock #1 wire tower, then its 8 and 4 and 3 a 6 and 5 and 7 and 2, all clockwse from that #1 tower
cylinders are numbers 1 3 5 7 on driver side bank and 2 4 6 8 on pass side bank
check rockers and # 1 rotor position and wire routing
if you get them adjusted right and wires right and its still doing this then soemthing else is bad wrong inside the engine
also the cylinder numbers are on the intake, look on the runners of the intake youll see a raised cast number on each runner, pretty big number
18436572 wire order(also cast on intake, behind carb base on top side out in open back there)
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 08-06-2005, 05:31 PM
yes i have pulled the dist. i replaced the pickup coil and put that back in i am currently waiting on my battery to recharge because for some reason my mark for were the rotor was pointing when i pulled the distributor came off so i have to play it by ear. I will check the rockers eventually but for right now i know for a fact that the timing is out of wack so first things first thanks for the suggestions, keep your ideas coming....Later.
L.A.W
Old 08-10-2005, 11:59 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
I like the too tight intake valve diagnosis (pops through the carb). But do check the timing. The bouncing timing marks are a good indicator of a tight valve. The distributor should be where it was when you removed it, even a tooth off will give you grief.
I always mark the distributor and a reference point on the intake manifold before I take anything apart. Just a yellow tire crayon mark on the distributor body and the manifold is good.
I adjust my valves with the car running. You might want to pick up a set of rocker stoppers (made by Lisle). They clip onto the rocker arms and stop the oil from spraying all over.
I let the car warm up first. I back off the lock nut until I hear it clack, then tighten it to the "zero" point, where the noise stops. I go a 1/4 turn, wait for the motor to settle out, then go another 1/4 turn. The book might say a full turn, but I'll go the 1/2 turn with a used motor and 3/4 turn for a new cam and lifter set. If the car runs rough at 3/4 and won't settle out, just back it off until it does.
This method has yet to fail for me, good luck!
Bob
Old 08-10-2005, 07:38 PM
CD Smalley CD Smalley is offline
Have disconnected the EST wire when you are checking/setting the timing? Not having this unhooked will cause the timing to jump all over the place while you are trying to set/check it...
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 08-11-2005, 09:57 AM
im in the process of figuring out how the distibutor goes back in (my mark rubbed off) it only sits back in there correctly 2 ways and i still havent been able to get it back running right it wont even fire, ill figure it out i have alot of things going on right now so it might be a while before i get back to it oh yea i changed the pickupcoil thats why i removed it in the first place i bought a new battery and like i said hevent even got it to fire back up its realy annoying youd have to be here to actually see what its doing before you can make a real assumption to what might be wrong. Thats all for now, packing my things to go to pennsylvania (i live in NC) for my grandfathers funeral dont know when ill get back to yall or to the car........later.
L.A.W
Old 08-11-2005, 10:00 AM
oh yeah 1 more thing, Whats the EST wire CD..thanks
L.A.W
Old 08-11-2005, 06:05 PM
Oh my. You have been setting the timing after doing all of that work and you don't know what the EST wire is?
It's a brown wire with a black strip, located on passenger side firewall. Disconnecting this disconnects the ECM from being able to control the timing. Otherwise the ECM is trying to control the timing the entire time the engine is running.
Trying to set the timing with out unhooking this is probably the source of most of your problems.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 08-12-2005, 12:28 AM
burnM's Avatar
burnM burnM is offline
CD, does your '86 have an est? I thought it would be a vacuum advance unit.... the first time I ever heard about an est was on my '91. I've had a few older Caprices and never saw an est with a carb.
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 08-12-2005, 05:37 AM
Yes my 86 does have an EST.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 08-13-2005, 02:14 AM
burnM's Avatar
That might explain why I always had to do the timing by ear....
