Old 07-28-2005, 09:26 PM
JstCloseUrEyes JstCloseUrEyes is offline
U-Bent Delete, does it actually do anything?
OK, folks
I've been around here for a little while, and I know, all of you GP fans swear by having a U-Bend delete...but
Now, I spoke to 4 professionals, one of which who "have built racecars for years," and ALL of them said that removing the u-bend will do nothing. Now I know by taking it out, it wont make the car go faster, or anything like that...but then, is it really necessary to take out.
What if i get a thrasher cold air box w/ a K&N filter, I mean, I assume that the U-Bend will cause problems, but, I was told otherwise...
...so.....the u-bend...does removing it do anything, or is it a waste of money?
2000 GP GT ~ Super Turbo Mufflers ~ Custom Dash ~ Owned by Poor College Student ~ Not Much Else Done ~ Saving for WS6 :-D
Old 07-29-2005, 12:59 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: U-Bent Delete, does it actually do anything?
Originally Posted by JstCloseUrEyes
OK, folks
In my opinion the u-bend delete is just a step in the total process of modding your car. In itself it may be worthless. No significant horsepower increase. However, taken in totality with other mods it probably makes a difference. For one, it doesn't make sense to have a hi-flow CAT, 2.5 inch downpipe or turbo mufflers if you have a bottleneck in the exhaust or something preventing flow or increasing backpressure.
The u-bend delete will not cause any problems with adding a Thrasher CAI.
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 07-29-2005, 07:24 AM
GTX Playa's Avatar
GTX Playa GTX Playa is offline
Send a message via Yahoo to GTX Playa
Looks like you need to read this ZZP Article.
Old 07-29-2005, 09:27 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Re: U-Bent Delete, does it actually do anything?
God, I was wondering when someone would give the right answer to that. Thanks Bob.
Old 07-29-2005, 01:27 PM
dmasjz45 dmasjz45 is offline
if your only adding a cold air box i wouldnt bother, it's not too bad stock..but if you mod more, plan on getting rid of it, either welding a peice on or going with a whole new downpipe and high flow cat
Old 07-29-2005, 10:17 PM
BigBL87's Avatar
BigBL87 BigBL87 is offline
Send a message via AIM to BigBL87 Send a message via MSN to BigBL87 Send a message via Yahoo to BigBL87
I've heard that it helps your gas mileage a little bit, dunno if thats true. Thats the main reason I'm looking at getting mine done, but 5 more hp doesn't hurt.
Old 07-30-2005, 12:40 AM
its not much back pressure stock, you wont make up for the gas money by paying to have it removed probably..i wouldnt worry about it unless you plan on modding heavily
