Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 07-28-2005, 07:17 PM
RevvRX-7's Avatar
RevvRX-7 RevvRX-7 is offline
Send a message via AIM to RevvRX-7 Send a message via MSN to RevvRX-7 Send a message via Yahoo to RevvRX-7
Would I need to change out the fluids if the car has been sitting..
for half a year? x_X
"Hand to hand. It is the basis of all combat. Only a fool trusts his life to a weapon."-Grey Fox -Gray fox (Metal Gear Solid)
"There is no good,there is no bad.Just perspective and opinion."-Squall Leonhart(Final Fantasy VIII)
"Love.. it is just an illusion which weakens and imprisons us."-me
Old 07-28-2005, 11:50 PM
FDTT FDTT is offline
Re: Would I need to change out the fluids if the car has been sitting..
I would just to be safe.
Change the oil, coolant and if you didnt add fuel stabalizer to the tank i would drain the fuel tank as well. But that is just me i always do it the best way i can. Im sure you coudl get away without doing it but why risk it.
Dont drive faster than your angels can fly
Old 07-29-2005, 02:41 PM
RevvRX-7's Avatar
So what would happen if you really needed to change out the fluids and you drive anyway?
Old 07-29-2005, 04:07 PM
Well if you really need th change the gas, then that means the particles have seperated that create the octane level. This coudl cause massive detonation and cause the apex seal to shatter.
Coolant, well not a heck of a lot, mainly rusting and lack of lubrication for the water pump.
Clutch fluid, may loose the clutch all of a sudden due to moisture or whatnot.
Brake fluid, same as clutch.
But if its only 6 months and the fluids were good at the beginning of the 6 months, then is SHOUDL be fine, but i take no responsibility if something goes wrong.
