Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-28-2005, 07:08 PM
DR1500 DR1500 is offline
Question cruise control
on my 95 SLT i have cruise but not working for sum reason..ive looked for the fuse but cant find it ive look in the side panel one and the fuse box under the hood.
Old 07-29-2005, 07:28 PM
john m john m is offline
Cruise control
Hi, I have a 97 1500. When I got it 8 mos ago, the Cruise control did not work. I re-seated every fuse in the panel on the end of the dash on the drivers side. That caused the light to start working in the switch on the wheel but the system didn't work. The final fix was the small(1/8") vacuum line at the actuator assy(located under the battery tray) Mine was broken off where the fitting goes into the actuator. I glued it with J B Weld and it still is solid as a rock. Good luck! John M.
