Old 07-28-2005, 06:10 PM
zeroiceman6977 zeroiceman6977 is offline
what all would make it go into failsafe mode
Old 07-28-2005, 07:56 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: what all would make it go into failsafe mode
hey, rather than start a new thread about a question you just got answered in another thread...simply POST AGAIN in that same original thread. as to your question, quite a number of things could cause it to go into failsafe mode. do a search, as this has happened many many times to people on here
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-28-2005, 08:10 PM
Linebckr49's Avatar
here's a freebie: http://www.automotiveforums.com/vbul...light=3rd+gear
possible problems include atx computer, electrical connections, and possibly others. best to just go get the codes read from the diagnostic port. if you have a datalogger or know someone that has one, that's your best bet.
OR
you can read the codes with an analog voltmeter. here are directions to do so: http://www.stealth316.com/2-diagcodes91-93.htm
OR you could take it to the stealership and let them charge you 70 bucks to hook it up to their fancy shmancy expensive diagnostic computer.
don't bother with autozone, or chain auto stores, they don't have the diagnostic connection to hook up to our cars, unless if your car is a 96+ 3000GT/Stealth. i'm pretty sure they would have OBDII equipment.
93 3000GT base
Old 07-29-2005, 06:45 AM
counld it maybe be my ecu and if i reset it it would work cause it only stays in 3 sometimes
Old 07-29-2005, 01:44 PM
Igovert500's Avatar
blue + red light magnet
no, something is wrong. You don't want to just reset the ECU, and see if it goes away. You want to pull the code and figure out what the problem is. Nobody here is psychic, we can't tell you what is wrong with it...we can only tell you to pull the codes.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
