Old 07-28-2005, 05:45 PM
GirlBear's Avatar
GirlBear GirlBear is offline
New 96 owner 4wd question
when im done in 4wd to i have to go in reverse to disingage the gears?
http://jowulf.deviantart.com/
Old 07-28-2005, 08:46 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: New 96 owner 4wd question
No, but hit the 2wd button only with your foot off the gas. Don't do it when accelerating.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-29-2005, 12:15 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
In the good old days of completley manual transfer cases, yeah, rolling in reverse helps in engaging/disengaging. But these push button trucks just need your foot off the gas when you switch between 4-hi and 2-hi. If you are changing into or out of 4-lo, you need to roll the truck at 3-5 MPH with the transmission in neutral before you hit the switch. Or when stationary and in neutral or park, hit the 4-lo button to engage, and again, in neutral and rolling at 3~5 MPH or park, hit any other button to change modes out of 4-lo.
Old 07-30-2005, 06:18 PM
GirlBear's Avatar
as i was lookin to see if any one replied to this thread. i noticed i put that i had a 96. ooops i meant 99, sorry guys. any hoo thanx for the info.
Old 07-30-2005, 06:25 PM
BlazerLT's Avatar
AF -Advisor
No problem.
Old 08-13-2005, 08:45 PM
GirlBear's Avatar
My blazer is a 96. On my title it sayss 99. Hmmmmmmmmmmmm. Not sure what thats about. sorry guys
Old 08-14-2005, 07:14 AM
DINO55's Avatar
DINO55 DINO55 is offline
Your forgiven this time GirlBear
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 08-15-2005, 01:37 AM
wolfox's Avatar
Probably the same reason why my 5300 pound truck says it's 3500 pounds on my registration. Long, long ago, in a typo far-far away in the bowels of your local DMV....
Old 08-15-2005, 05:15 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
99.... 96....69... It all works for me . Just send more pictures . When I undo 4x4 to 2x4 . I don't do any kind of special foot work , Girlbear. Since these shifting units rely on vacuum and a release of force from either the road surface or transmision speed. It will undo itself when the time is right . Sometimes it could take a couple of minutes or miles . The transfer case should release pretty quick but the indicator on the dash will only change when the front axle is finished as a complete disconnect. Rob
