Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 07-28-2005, 02:13 PM
butrfly002 butrfly002 is offline
Send a message via AIM to butrfly002 Send a message via Yahoo to butrfly002
Engine swap question
Trying to put the engine from a 78 Jeep manual transmission (not sure exactly what it came out of) into a 1983 AMC Eagle automatic. Engines appear to be identical I have: removed the clutch and flywheel from the new engine. I installed the flex plate from the old engine, but can't figure out how to install the torque converter from the old engine. It won't fit into the bellhousing. Someone told me I need a special tool to put it in? Done several engine swaps before and I've never had this problem, any advice would be appreciated.
Old 07-28-2005, 11:33 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Engine swap question
What do you mean 'won't fit'? Didn't it come out of that transmission.
Before the engine is bolted to the trans, you slide the torque converter neck into the transas far as it will go. You then need to rotate the converter up to half a turn while pushing gently. The converter will rotate a bit then slide about another half inch into the trans. Then attach the engine.
