Old 07-28-2005, 12:20 PM
BuckyMagoo BuckyMagoo is offline
Angry 4 WD stuck in Low range HELP!
Help! My 2000 Chevy blazer is stuck in 4 Low, that darn electronic button control seems to try to shift it out into 2H, but doesn't seem to go all the way. The light blinks for a few seconds, then it seems to give up. Anyone know anything about this? Itried putting it from nuetral into park, tried going into 4H, nothing. I'm open to trying almost anything.
Thanks,
BuckyMagoo
Old 07-28-2005, 12:25 PM
Cailen Cailen is offline
The easy things to check are:
-is the 4x4 fuse burnt?
-is your transfer case too full?
To check if the Tcase is too full you can open the upper (fill/level check) plug. If transmission fluid comes pouring out you could have a faulty gasket.
If it isn't one of those two problems it can be the switch, vacuum line problem, or the actuator motor itself. If your switch is flashing I would venture to guess it's not your switch. If you're hearing a clicking I would venture to guess it's a too much fluid problem or a vacuum problem.
Old 07-28-2005, 12:34 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: 4 WD stuck in Low range HELP!
Do a search been covered alot of times.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 07-28-2005, 01:02 PM
Thanks for your help! I hear a click/click. Where is the vacuum line? I have never added fluid, so doubt that it could be a high fluid problem.
Thanks,
BuckyMagoo
Old 07-28-2005, 04:20 PM
I had never added fluid either, yet 2 quarts came pouring out of the level check plug. The Tcase is connected to your transmission, and if the gasket between the two is faulty you could have fluid leaking very slowly from the tranny to the Tcase.
It's easy to check, just need to pull the plug.
Old 08-02-2005, 01:31 AM
snowcobra99 snowcobra99 is offline
my 1999 did the same thing.turned out to be a small box (computer)above the tranfercase the plug turned corroded(green)cleaned it off and no problems for over a year now.
