Old 07-28-2005, 12:10 PM
rock0134 rock0134 is offline
Send a message via AIM to rock0134 Send a message via Yahoo to rock0134
2 good questions
Question #1: I got my New CD player installed quite a while ago and i havent been able to figure out why the antenna raises every time i turn the car on, even if i am not using the radio. It never used to be like that with the stock cd player. The antenna would only raise if i would use the radio. So im wondering if it is a wiring problem that can be fixed or if thats the way it has to be.
Question #2: Since getting my EVO III turbo i havent turned up the boost at all. I went to turn the boost up using the TURBOXS mbc the other day and it doesnt work for turning the boost up. It was professionally installed and all of hte connections are still made with the mbc.
Oh yea and im going to race in Rock Falls, Wisconsin this weekend for the first time... is anybody else gonna be there?
Old 07-28-2005, 12:21 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
My antenna dosn't raise at all anymore. I don't really know why, all the connections are accurate. I know the antenna works because it did right before I put the new cd player in. I didn't feel like tearing the thing apart again, it's such a pain getting it all back together.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-28-2005, 01:36 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: 2 good questions
Question #1: I have no freakin' clue. I let the audio questions to the other guys. I always seem to fry something when I try to hook head units up
Question #2: Are you sure you are turning the MBC the correct direction? What is your boost level right now? Was the MBC functioning correctly before the turbo installation? Is the MBC bottomed out?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 07-28-2005, 02:04 PM
yea im doin it the right way and yes it was working before with the stock t25 turbo. The boost level is at only 10 psi right now so...
Old 07-28-2005, 07:50 PM
kjewer1 kjewer1 is offline
AF - Advisor
#1) Odds are the supply to the antenna was connected to a switched 12 volt source, and not the CD players power signal wire, perhaps becuase it doesnt have one for some reason. I have to think that every modern aftermarket head unit is going to have an auxiliary turn on wire though. Could be installer error.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-28-2005, 07:58 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
#1 easy fix is to wire the antenna to the amp remote (aux 'turn on' wire)
#2 your MBC isn't hooked up properly to the wastegate actuator.
