Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-28-2005, 10:12 AM
HockeyBH HockeyBH is offline
Question 1991 caprice classic Problem
Im sitting here at work reading all the responses to eveyones problems tryiing to figure out my own. My car is overheating up to the redline. took it to a local shop who said nothing was wrong with it, but i had them change the thermostat. He said that helped keep it cool. Picked it up drove about 3 miles, overheated, went back to shop and it overflowed in their parking lot. Im going to fix it myself now... Im thinking about changing the waterpump, and adding an electric fan on the front of the radiator to help it stay cold, after i get off of work. Has anyone put a electric fan on their 1991 caprice classic? Also I too need to fix my antenna, its stuck with the motor running. I pulled the fuse but my horn, and interior lights dont work. I have to take it in for safty and inspection this week, should i get a new one and put it in. Is it hard? Thanks Brandon
Old 07-28-2005, 10:20 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
before you replace the water pump, check to make sure that you have enough coolant, ir just get a system flush
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 07-28-2005, 11:10 AM
Re: 1991 caprice classic Problem
I just got an oil change with the works about 4 days ago, its full with fluid.
Maybe ill get the system flush to see how that works. Im not too familiar with system flushes, but is it just a chemical that cleans it out good? Also is there a way they can check my radiator cap for holding the pressure?
Old 07-28-2005, 03:35 PM
KCBigTimer KCBigTimer is offline
Send a message via Yahoo to KCBigTimer
ok well to answer your question about the electric fan on a 91 caprice classic. i own a 91 LT1 caprice and i installed an electric fan on mine and seemes to work wonders in the summer time for me i haven't had it in the winter time yet but i can't imagine me having problemns with it in the winter
Old 07-28-2005, 07:56 PM
Re: Re: 1991 caprice classic Problem
Where did you get your fan? and what model number is it if you remember?
Old 07-28-2005, 09:10 PM
i ordered it from my old job at Keystone automotive you can go to www.driverfx.com and search for it the electric fan i got was designed for the early 90's impala and required very minor modification basically drilling holes and bolting it in place. i can't remember the part number of my head i'll try to find it for you but no promises
Old 07-28-2005, 10:32 PM
Talking Re: Re: 1991 caprice classic Problem
No problem, ill will do some searching on my own as well. Thanks to all for your help...
Old 07-30-2005, 03:36 AM
getfreshco getfreshco is offline
my 91 overheated on me also....at first it would be alright but when i was idle thats when the temp would rise......i got a new water pump and thermo.....flushed it and then intsead of a 50/50 mix of coolant(dexcool i think) i just kept it undiluted ....worked perfect for me!.......i going to get a new radiator soon just cause the one i have is the original(old) tell me how that electric fan works out
Old 08-06-2005, 01:33 AM
capricesrgreat capricesrgreat is offline
I had the same same problem on my first caprice. I replaced the fan clutch with a heavy duty version I got from autozone for about $40.
Old 08-10-2005, 11:59 AM
***UPDATE***
I changed the water pump, cleaned off the Fan, and Flushed my Radiator... Works like a charm. Im still thinking about putting on the electric fan to have colder AC. Thanks for everyones help. Now time to fix my toyota.
Old 08-10-2005, 09:32 PM
1986Z28's Avatar
Has a Camaro
Originally Posted by HockeyBH
***UPDATE***
good luck with the toyota their pieces of crap
Old 10-23-2005, 02:37 PM
Mira_cz's Avatar
Mira_cz Mira_cz is offline
Send a message via ICQ to Mira_cz
2 electric fans were standard on Impala SS, try to figure it that way. Or, change the wather pump, youre problem seems like this kind of problem.
Old 10-23-2005, 05:20 PM
There were no LT1 caprices in 91, and there weren't any impala ss cars either
Old 10-23-2005, 06:52 PM
HLandin's Avatar
HLandin HLandin is offline
He has a point; the 91 Caprice did not come with the LT1, but this has been discussed in previous posts. Unless the original engine has been replaced, it came either with the L05 or L03, not LT1.
Old 10-24-2005, 01:21 PM
1986Z28's Avatar
Has a Camaro
mira please dont ressurect threads
