Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 07-28-2005, 08:00 AM
JamesAlx JamesAlx is offline
TAX Exempt 1971, 1300 Beetle with 1600 Engine for Sale
White 1971 1300 Beetle with 1600 Engine
Good Points:
  • Reconditioned lowered front beam
  • Front beam fitted with sway-a-way so you can change the hight with 2 bolts
  • New steering damper and new front brake lines
  • Fitted with reconditioned front disc brakes (requires new brake pads)
  • Great enterior, with all carpets, door cards
  • Original seats in great condition no rips or tears
  • Empi quick shift (comes with spare original gear stick)
  • Chrome running boards (comes with spare original black running boards)
  • Parcel shelf with fitted speakers
  • Electric screen wash
  • Tax exempt
  • Loads of history
Engine:
Standard 1600 engine, with Solex carb with tower air filter (see pick)
Newly fitted; coil, HT leads, spark plugs, air filter, oil air filter,
glass fuel filter and fan belt
New Exhaust and heat exchangers
All fuel pipes replaced with new jubilee clips
Recent oil change and new oil gaskets fitted (only done 1mile with new oil)
Very little work is needed to pass MOT:
  • Fill and bleed brake system
  • Replace both heater channels
  • Replace rear quarters of both floor pans and jacking points, see pik
  • Fibreglass or replace bottom of front valance, see pik
  • Passengers side needs attention / filling door and quitter on passengers side, see pik
Bad Points:
Well pretty much as above.
Needs new heater channels (You could patch but always best to replace with new).
Needs patching/welding on the floor pans on the jacking point area on both sides. You will need to get an outer quarters section of the floor
pan for both sides, the rest of the floor pan is solid. It's just rusted where the end of the heater channels are. Had some rust under both rear air vents, this is prevention, rather then reconstruction see pik. Also there has been the same on the passengers side door and rear quarter.
I'm reluctant to get rid of this fantastic car but I don't have the space, ability or time to do the project.
This car is sold as seen viewing is strongle recomended.
This means that if you do not view you are buying the car from the pichers.
The description is a rough guide, but I have tried to list this as best as posible.
This car will need to be traylerd away due to braks.
Pictured wheels don't included, this wheels will be sepratly auctioned.
As stated above viewing is recomended.
Payment must be recived priyer to colection of car via PayPal.
This payment must be made within 5 days of end of acution.
This car must be collected within 7 days of end of auction.
Please do not bid unless you have a rating of 5+ positve. If you don't know what this means then do not bid on this auction.
If you do place a bid and do not meet these requierments I will simply cancel you bid. So please do not wast my time and yours. NO EXCEPTIONS. I do not except Western Union Bank transfers or any other type of bank transfers from any country so please do not ask. No tire kickers.
Thank you!
You can bid at:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=4564887821
or make me an offer I can't refuse!!!!
Old 08-14-2005, 12:01 PM
Doug Rodrigues Doug Rodrigues is offline
Send a message via MSN to Doug Rodrigues
If I remember correctly, the 1300 cc engine was made for the '66 VW Bug and was a 6 volt system. The 1967 VW Bug was 1500 cc and a 12 volt system. Where did you get a '71 with a 1300 cc engine?
