Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-28-2005, 01:28 AM
forfeit forfeit is offline
need help picking out my first caprice
Hey all.. I've recently gotten interested in getting a caprice as my first car. I've always liked the bigger cars, and I love the look of the caprice cop cars from the early to mid 90's... so here I am. I live in canada and have been checking out the local Auto-Trader mag's seeing what was avaliable and the prices for them. From what i've seen, a used caprice will run me about $2000-$3000 CAD, which is pretty decent I think, but what I'm not to sure about is which year(s) I should be looking for. originally I was interested in the 91-93 caprice's, but over the last little bit of reading on here and on other places I found on google, it seems most people want the mid (93-96) caprice's. I have a few questions that I was hoping all you Caprice lovers/freaks would be able to help me out with.
1. What are the benefits of the later years over the earlier? (93-96 over 91-93)
2. How do you tell if it's the 9C1 (police package) version of the Caprice or not? are there any eaasy ways to tell?
3. does anyone know of any companies that make body kits for the caprice's
and any other helpfull info you can provide.. websites, etc.. I'm interested in reading just about anything I can on them.
Old 07-28-2005, 09:05 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
the 91-96 are good years, if its a 9c1 it will have 9c1 on the spid on the trunk lid
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 07-28-2005, 03:45 PM
KCBigTimer KCBigTimer is offline
Send a message via Yahoo to KCBigTimer
Re: need help picking out my first caprice
i own a 91 LT1 caprice with an engine swap with an intercepter and i strapped on a supper charger just for kicks. i've search in and out and the results for body kits is a negitive. the only thing i have found is custon "bentley styled" grill so sorry no body kits
Old 07-28-2005, 06:51 PM
HLandin's Avatar
HLandin HLandin is offline
Each model year seems to have its advantages and disadvantages.
Many prefer the 94-96 year because it came with the 350-cid LT1.
After 1991, the Caprice had a gear driven water pump instead of a belt driven one (gear driven is supposed to be more reliable).
The Caprice body was drastically changed in 1991 from the boxy to the bathtub and stayed that way (despite some minor exterior changes) until 1996.
From what I've heard, the Opti-Spark ignition system used from 1994 to 1996 was fairly problematic.
350-cid V-8 was available with police Caprice (9c1) from 1986 to 1996. The 350-cid had four barrel carb from 1986 to 1988, throttle body injection from 1989 to 1993, and sequencial multi-port injection from 1994 to 1996. Was also available with 262-cid V-6 from 1986 to 1990, 305-cid V-8 from 1989 to 1993, and 265-cid V-8 from 1994 to 1996.
Rear end gearing on 350-cid was 3.08 ratio from 1986 to 1988, 3.42 ratio from 1989 to 1993, and 3.08 ratio from 1994 to 1996.
You can tell if it is a 'police package' car by looking on the Service Parts Identification (SPID) label in the trunk. If the label says 9c1, that car was made from the factory with police package options (heavier duty frame, brakes, suspension, etc.).
Old 07-28-2005, 11:19 PM
Wow HLandin, thanx for all the info.. that detailed just about everything I needed to know.
Thanks to everyone who postted
Old 07-29-2005, 12:58 AM
Mercurybarring Mercurybarring is offline
hey man check out www.streettrends.com
Old 07-29-2005, 07:49 AM
1986Z28's Avatar
Has a Camaro
on ebay they got front and rear smooth bumpers, and one custom
Old 07-29-2005, 02:04 PM
HLandin's Avatar
Also, forfeit, here are the vehicle brochure from Chevrolet:
1989 - http://www.9c1.com/brochures/1989/89_9c1.pdf
1990 - not available, but only thing that changed from 1989 to 1990 was the usage of different front seat belts (active to passive) and a boost in compression (9.3:1 to 9.8:1)
1991 - http://www.9c1.com/brochures/1991/91_9c1.pdf
1992 - http://www.9c1.com/brochures/1992/92_9c1.pdf
1993 - http://www.9c1.com/brochures/1993/93_9c1.pdf
1994 - http://www.9c1.com/brochures/1994/94_9c1.pdf
1995 - http://www.9c1.com/brochures/1995/95_9c1.pdf
1996 - http://www.9c1.com/brochures/1996/96_9c1.pdf
Hope this helps
Old 07-31-2005, 10:22 PM
ncinirator's Avatar
ncinirator ncinirator is offline
Send a message via AIM to ncinirator
I have two caprice's I`m getting rid of. Both are LT1's with positraction. One has a power drivers seat. e-mail me if your interested.
94 Caprice 9C1, 84 CUCV Blazer, 07 TL, 96 F250 PSD.
