Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-27-2005, 11:38 PM
supreme95 supreme95 is offline
Question replace thermostat- 95 cut supreme
I have the 3.1 engine, and I need to put in a new thermostat but can't find the housing. How do I get to it, and put the new thermostat in?
Old 07-28-2005, 11:10 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: replace thermostat- 95 cut supreme
Follow the top radiator hose to the engine. Where the hose connects to the engine is the thermostat hosing. Drain the coolant down slightly and remove the two bolts that hold the thermostat housing in place. Gently remove the housing. Clean off the old gasket material from the manifold and housing, pull out the old thermostat, put the thermostat back in place, reinstall the new gasket, reinstall the housing being careful not to overtighten as it will break easily. Refill radiator and start the car. Make sure to top off the coolant level and check for leaks.
