Old 07-27-2005, 11:21 PM
tripod12133 tripod12133 is offline
Send a message via AIM to tripod12133
how much horsepower ?
okay i have a stock 305 out of an 84' monte. and i have modified the following:
I have added:
Headers
A new 600cfm edelbrock
Pete jackson gear drive
Accel coil pack (but no accel wires or plugs)
removed:
A/c compresser
Smog pump
egr valve.
Both catalytic converters
given what i have removed and added, what do you all think the horsepower may be at right now ? I think it was probably around 225 to begin with but im thinkin this:
Headers: + 10 HP
600 cfm: + 10 HP but not sure/if any
Gear Drive: + 5 but not sure if any/is there truer timing ?
accel pack: ???
what do yall think ?
Old 07-28-2005, 12:23 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: how much horsepower ?
well i would put your factory hp closer to 170, with the headers and other mods id say youve probly broken 200, maybe 210 or 220 total.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-28-2005, 12:07 PM
Re: Re: how much horsepower ?
dam. thats not much of anything really. any cheap ways of improving the horses substantially ? I was also thinkin about gettin a supercharger for around 900 bucks but i probably wont. my goal is to have it at 300 HP. and even at 220 HP, are they still that fast ?
Old 07-30-2005, 10:07 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
you need intake and cylinder heads. intake will be much less expensive ~$120. also new intake will probably not allow air cleaner to fit under the factory hood.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 07-31-2005, 02:37 AM
well cylinder heads are out of the picture czu the motors really done. how much HP would an edelbrock High rise intake add ? I dont think any of thats gonna be a problem. I bought a hood from www.americansportscar.com and its about a 4'' ram air hood. Its the big block hood in red paint (for 82-92 camaro's) part # s-290. The hood is awesome.
Old 08-06-2005, 09:46 PM
stepho stepho is offline
Send a message via AIM to stepho Send a message via Yahoo to stepho
Re: Re: Re: how much horsepower ?
I love that hood. I am debating on getting the hood or a paint job...
Originally Posted by sportlinetta
lol, u guys are dummmmmmmmmmmmb im 14 n i know more. i gotta 88 camaro.
would that mean get a new cylinder or plug???
Old 08-07-2005, 02:17 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
im getting the fiberglass SS hood either from them or from http://www.hawksthirdgenparts.com/in...?v=1&pid=10107
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 08-07-2005, 04:02 PM
Morley Morley is offline
If it was an SS, you started with 190 HP and might be pushing 220 now. If it was a plain jane Monte, 140hp to start and migt be up to 160 now.
Old 08-07-2005, 09:23 PM
hey man. I would go with www.americansportscar.com just because i was strapped for cash and they let me pay on it for 2 months til i had it payed off. After i talked her down, the hood was $ 325 which isnt half bad at all, especially for that hood. and with my experiences, hawks thirdgenparts are just too dam expensive. but best of luck.
Old 08-07-2005, 09:24 PM
so my addiditions now include
high rise performer intake
headers
gear drive
new 600 cfm carb
and soon to be, msd ignition system.
ive removed:
smog pump
a/c compresser
and my only catalytic converter
im just tryin to squeeze every last ounce of HP out of the ole 305 and i may have hit my limit.
Old 08-08-2005, 01:53 AM
If you started with the 140 hp engine, you're wasting time, it was low compression and had a crappy cam.
If you have the 190hp HO engine, you could probably get it to 225 easily and 300 with some internals changed; cam, 1.6 rockers, thinner head gaskets to bump the cr up a little and porting of the heads.
Now, if you have the crappy "swirl" heads, get rid of them and latch onto a pair of 1985 TPI heads and port them (yourself, because it isn't worth the money to have them done).
Old 08-09-2005, 06:14 PM
BUt its hard to believe that a chevy 5.0 can only come from the factory with just 140 HP ! Thats not anything . I cant believe it could get that low. i was thinking at worse.. maybe 170 HP. well im not doubting you but in my opinion i really dont think it started with just 140 HP. I think it started prolly near 180-170'ish and is probably near 220-230 by now.
ps: how much do new aluminum or just new good heads Improve HP ?
Old 08-10-2005, 08:03 AM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Re: Re: Re: Re: how much horsepower ?
Heads are the best way to make hp, if u have a good set of heads that flow good u can really build big hp with a few other mods like a good cam,intake,carb,headers,and a good catback. But don't forget to upgrade the trans,rearend,and suspension.
This is what 500 plus hp looks like.CNC ported AFRHEADS WITH 2.02 INT 1.60EXH,210 intake runners 74cc chambers, 750 speed demon carb,weiand intake,comp cams 292 with .501/.501 lift ,4340 forged crank,eagle H-beam rods duroshield bearings,KB forged 10 1/2:1 pistons,headers with 1 3/4 primaries ,MSD 6AL,comp cams pro mag1.6 rockers,holley blue pro-series pumps,MSD billet distributor.All stuffed into a 355.[img][/img]
Old 08-10-2005, 07:54 PM
Re: Re: Re: Re: Re: how much horsepower ?
hmm... what are catbacks ? and replacing heads usually arent that hard.. right ? I think you just take off the valve covers and unbolt the head bolts and it slides right off.... I think.
Old 08-10-2005, 10:44 PM
Sending you a PM right now
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
