Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-27-2005, 11:19 PM
smfleming smfleming is offline
89 Wrangler lopes while idling
Hey there all..newbie to the forum in seach of the that perfect day when my wrangler runs like a dream
Ok here goes..hope someone can suggest a remedy. I have an 89 wrangler. When she starts from cold in the morning she runs well, idling steadily at about 8,000 rpm. However, after driving her for a bit and the engine starts to heat up the idling becomes eratic when she comes to a stop. It kinda lopes between 8,000 down to about 3,000 rpm..sometimes so low that she dies on me. I've looked at the Haynes manual and they suggest about 10 possible different problems, the first being vacuum leaks..but I see no chapter on how to check this or where to check. If anyone can offer any suggestion as to what to check first or what they think the problem would be I sure would appreciate it.
Thanks
Stephen
Old 07-28-2005, 04:50 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
I think you mean the jeep has an idle of 800 rmp, not 8,000. Easiest way to check for a vacume leak is to take a can of carb cleaner and spray it around the hoses while the jeep is @ idle. If the jeep suddenly tries to stall when spary a certain spot, you've located your leak. Usually with a vacum leak, the idle will go up and down constantly.
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 11-29-2005, 01:00 AM
jea12 jea12 is offline
did you check the e.g.r. valve.
