Lost power and died
Any idea what could cause the motor to pop like a backfire then just die and loose all power like I had turn the damn thing off. I still had lights and all electric seemed operational. I had Autozone just read my codes and was told that I had random misfires. Was going to get replacement coil packs when this occured. Any help would be appreiciated.!!!
Re: Lost power and died
Crank Position sensor failed and caused the engine to shut down. While you are at it change the plugs and wires along with the coils. Bad wires will damage coils. But your major issues is with the CPS.
Thanks, I will look at that. I just pulled the front valve cover to find my main timing chain with slack in it so I am trying to find a diagram to show me more of what I am looking at. I would say the two are gonna go hand in hand.
since you are all ready ripping it apart look at getting an alldatadiy.com account for $25 a year.
you need an OBDii scanner to read (and write down)those computer codes. That should be your first step. Post the codes here if you want. I wouldn't be taking anything apart until I got the codes read unless there were no codes to begin with. |
Re: Re: Lost power and died
If the timing is spot on then check the connections to the CPS and Cam position sensor. If either are misaligned or bad you will not get a spark. One question, are you getting spark but it will not start or are you not getting spark at all? Different items to check if it is spark vs fuel.
Pull a spark plug wire and with an old plug ground it against the block. This is the old method and most would critize me for telling you to do this but hold the wire with insulated pliers and turn it over once or twice. If there is spark then you have a fuel issue if not try the items I mentioned. Also I would do a compression check to make sure that nothing was damaged when the car backfired. Let me know what happens.
