somebody's going to be busy this weekened
I think the pictures speak for themselves . . .
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Re: somebody's going to be busy this weekened
SEX. Post pics of her when you get done.
Once PearlGT, now RaidenKing. Sr20det - Greddy V-SPL front mount intercooler, MR DP, Walbro 255 Fuel pump, Type RFL BOV, Koyo Radiator, MR straight pipe/muffler. Greddy Profec II, D2 Coilovers. In the garage - MR Headers, outlet, z32 maf, z32 brakes, home made tails. Near Future - 5 lug conversion w/ z32 brakes installed and decent lsd.
beautiful. Dimensions? And I know you mentioned it, but I don't remember, did you say you already have a buyer lined up for your DSMs??? If not I'll have the $$$ September or REAALLY early October to be spending on my car again.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: Re: somebody's going to be busy this weekened
Dimensions are 31x14x2.75, this is the larger core that Custom Coach sells for our cars, capable of effeciently flowing 1200 CFM. As far as the DSMs, i had already sold them to a 3SI member who lives 2 streets over from me, and i had already installed them for him. If I still had them, i would have been more than happy to sell them to you. If you still want to tackle the project, it cost me a total of $330. I bought both of the DSM sidemounts from dsmtrader for $80. I then took them to a guy i know (in your case, your welder) and he had to cut one of the end tanks off, reverse it, plug up a hole and drill a new one. Then he took the stock piping off of my stock intercoolers, cut them and welded them on the DSM intercoolers. Of course, you can just buy mandrel bends if you want, they will work just as good and you can sell your stockers. And finally i lined up the DSM sidemounts, marked where new brackets should go, took them back to the guy doing the welding, and he welded new brackets on, and i had DSM sidemounts. Remember though, when doing brackets, you only need one bracket bolted on the car per sidemount. There is no need to have all three if its going to be too much trouble. One bolt per intercooler worked fine for me.
shweet! are you gonna keep the stock IC pipes or get new mandrel bent piping? do you prefer mandrel over regular bends (non-uniform radius thru bend)? i know some guys that DON'T like mandrel b/c when the pipe is bent, the outer pipe wall becomes thinner than the rest of the bend causing a potential instability. either way you go, mandrel bends give you about 15%-20% better flow and look better IMO.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Do you know how to weld? The cold side of mine refused to fit until I chopped it up and welded it back together so it would fit, so just a heads up. Good luck.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions. |
are you trying to hint that those intercoolers are air to water cooled or w.e.???? Cuz that water bottle is pretty misleading other wise
Georgey on the subject of midget beastiality pornos Quote:
R.I.P Andy, you will be missed by all. |
Um, no, he is showing you the size of the IC in relation to something you can hold in front of you.
Color me jelous!
Resistance Is Futile (If < 1ohm) |
![]() I will probably hold out until i get my body work done (parts are in the mail right now) before i post up any pictures.
ok, i'll give ya'll a small taste
after drilling holes and boring out sheet metal, which is a pain, i've finally mounted it. Here are pics. Sorry that the garage is soo messy, i just have tons of crap lying all over the place.
nice rug! i bet it makes the mechanical experience almost luxurious
. but you're mother would certainly not be happy
^hahah... hey hotshot, I thought you said you're still using stock SL pistons rite???? If so are you gonna' do a swap with that too???? and thanks for the clear-up talskinny.
Is it just me or is that touching the ground?
