Old 07-27-2005, 09:06 PM
AutostradaVR4 AutostradaVR4 is offline
Unhappy HKS Type 1 turbotimer innacurate
OK, had the HKS Type 1 timer installed for a little while now, but just got around to wireing it for all the goodies (speed, revs, etc.)
Problem is, it seems to be horribly innacurate. According to the car, im at 2000 revs, but the timer reads like 4000. Anyone have one of the Type 1's in their car here? All i can think of is that theres someway to change the engine setting (4 cyl, 6 cyl, 8 cyl, etc). i read the junky manual and looked online but couldnt find anything. Anyone have any ideas?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 07-27-2005, 10:32 PM
Igovert500's Avatar
blue + red light magnet
Re: HKS Type 1 turbotimer innacurate
You sure you installed it correctly?
http://www.team3s.com/~egross/3S/Mod...mer/index.html
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-27-2005, 10:51 PM
mitsuGTvr4 mitsuGTvr4 is offline
i have a HKS also, not sure if its the 1 or 2, but it's also off when it comes to revs. Usually its below what my tach says.
Old 07-27-2005, 10:53 PM
Igovert500's Avatar
I have an HKS, and I'm not even sure it shows revs. All I get is the turbo timer features, and battery voltage.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-27-2005, 11:04 PM
Stealth-Twinturbo Stealth-Twinturbo is offline
YOU NEED TO SET THE SIGNAL PUT IT TO RPM MODE AND PRESS T2 IT WILL FLASH 2000. Then bring you tach to 2000 Rpms and press T2 again and it will change the signal and be correct.
92 Stealth R/T TT
CURRENT MODS:
K&N FIPK
Spec Stage 3 Clutch 6 Puck
HKS Turbo Timer Type-1
3 Inch Polished Y-Pipe
Greddy Profec B Spec II @ 12.0psi
Greddy Type S BOV
Greddy Catch Can
Borla Exhaust
3 Inch SS Down Pipe with Race Pipe
3SX Crank Pulley
Accel 8.0mm Wires
Gen 3 Lifters
High Flow 290lph Fuel Pump (Supra Pump)
Plugs Gapped at .030 Iridium IK20's
550cc RC Engineering
Apexi S-AFC II (WILL BE REMOVED NOT YET)
2 G-16 Turbos
AEM EMS
FUTURE MODS:
Custom FMIC
Old 07-28-2005, 01:12 AM
YOU NEED TO SET THE SIGNAL PUT IT TO RPM <<MODE AND PRESS T2 IT WILL FLASH 2000. Then bring you tach to 2000 Rpms and press T2 again and it will change the signal and be correct.>>
Beautiful. Awesome. Your the man. Very much appreciated.
Formerly BlinkRA182
