Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 07-27-2005, 07:38 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Idle surging? idle problems
My mom has a 1992 elantra and at idle the rpms rise and fall...sometimes stalls...
I guess my question is... would this be idle surge? What would cause this to happen and what are things I can check for that might cause it?
Any help and/or suggestions would be greatly appreciated...
Another side question is...The engine is an 1800 and looks almost identicle to a 4G63turbo in an eclipse/talon/laser... is it basically the same just smaller? I know it isn't a turbo.. duh... but when I popped the hood I just about shit cause it looks just like the one in my old eclipse spyder...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 07-31-2005, 09:48 AM
so4lr6 so4lr6 is offline
2001 elantra 70K miles. I had similar problems with my car...However, my car soon threw fault codes (check engine light), eventually lead me to the wiring leading to the IDLE SPEED CONTROL unit. One of the wires was broken and would cause erratic idle and eventual stalling when coming to stops....If your car is not throwing codes, then it could be various other problems, ie. air intake system, alternator, throttle control...
As for the simiarity in with the mitsubishi...i know that earlier hyundai models shared significant hardware with mitsubishi motors, but couldn't tell you if it is the same as the eclipse.
good luck
Old 08-01-2005, 11:47 AM
Re: Idle surging? idle problems
thanks for the response so4lr6... Next time i'm up at my ma's i'll look into that... I did check minor things like intake and such... everything seems fine...
No fault codes yet....
Old 08-01-2005, 04:13 PM
OC2Vegas's Avatar
OC2Vegas OC2Vegas is offline
97 elantra...same problem! check the connection on the Throttle position sensor. has a way of comin just a bit lose so its not seated all the way...
http://server3.uploadit.org/files/OC2Vegas-Truck1.JPG
2003 Silverado LS Xtra Cab
5.3 Liter
K&N Intake
MagnaFlow 3" Cat Back
Old 02-14-2006, 08:42 PM
Chalkybones Chalkybones is offline
Gidday. I'm new to this site. I have a '98 Elanta (called Lantra in Australia) and have the same idle problems. Can you tell me where this idle speed control unit or throttle position sensor is located please?
Thanks.
