Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 07-27-2005, 07:02 PM
bubsthechub bubsthechub is offline
noise around 40mph
I have a 2004 1.8L Turbo Passat and recently, I've been hearing a thumping noise when I reach about 40 mph. Anyone experience this or know what this might be? It sounds like a low hollow thump. Thanks
Old 07-27-2005, 07:23 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Does it make the noise when you hit bumps or does it make the noise all the time?
Check under your car and see if the lower engine cover is attached all the way (make sure its not hanging down).
There are 3 screws in the back, 3 in the front, and 2 on each wheel well that hold it onto the car.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 07-27-2005, 09:28 PM
It's making the noise all the time. Not just when going over bumps. I'll check the lower engine cover. My dad recently changed my oil so maybe he didn't screw it back on tightly enough. Does the engine cover need to be removed to get to the oil filter?
Old 08-02-2005, 08:24 PM
VDUBMAN
no, but it needs to be removed to get to the drain plug.
