Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-27-2005, 03:59 PM
bdm bdm is offline
misfire
computer code reader says one or more cylinders misfiring
i put in new plugs,2 new coil paks-they were under or at bottom limit,and ignition module checks good. but didnt make much difference.
it will start-but wont run good enough to drive. it wont idle-it does seem like a cylinder is misfiring--any ideas?? code reader says same code as before putting in new parts. thanks for any help!
this is a 96 sunfire-gt-2.4
Old 07-27-2005, 09:25 PM
phillipgr phillipgr is offline
Re: misfire
You need to do a compression check to see if it is losing compression
Old 07-28-2005, 01:56 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: misfire
Did you check the connectors between the coils and the plugs. They call them wires but they look more like connectors. I would replace the other two plugs at the same time. What code are you getting from the reader?
Old 04-27-2006, 01:39 AM
xtremamu xtremamu is offline
Re: misfire
sounds like that plastic (tower) coil houseing..
Closed Thread
