Old 04-28-2002, 09:28 PM
igo4bmx's Avatar
igo4bmx igo4bmx is offline
Banned
Send a message via AIM to igo4bmx
AEM/Nissin pads dead after 12k miles...
Here are some pics.
the braking power was a little bit better than my OEM pads, but i must say the OEM pads last much longer.
I replaced my OEM pads after 23k miles ONLY because i wanted to put these pads on.
These pads however went down to the BARE metal as in the second picture. and only 12,000 miles
I just bought another set of OEM pads and I'm happy with them, knowing i won't have to change them in a while. Plus they are cheaper.
Old 04-28-2002, 10:01 PM
CivSiGuy's Avatar
CivSiGuy CivSiGuy is offline
Banned
Send a message via AIM to CivSiGuy
well at least I know I wont be buying those
Old 04-28-2002, 10:37 PM
igo4bmx's Avatar
Banned
one thing to add:
my brembo rotors haven't cracked and luckily lasted through these AEM pads.. even though the pads were down to the metal, the rotors don't have any signs of uneven wear.
Old 04-29-2002, 07:58 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
My AEM pads lasted 20K miles, 30 autocrosses, and one track day. Something weird was happening with your brakes.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 04-29-2002, 09:50 AM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
I agree... sounds like something isnt right
AF's Official Asshole
RIP AUNIE
Old 04-29-2002, 10:41 AM
igo4bmx's Avatar
Banned
civicsiracer, what rotors do you have? i have a theory that maybe the drilled holes in my rotors are not smooth enough and are chipping away at the surface of the pad.. either way OEM seems fine for me.. i'll see what happens with them
Old 04-29-2002, 12:25 PM
Civic Mod
I had PowerStop Cross drilled rotors (front and rear) with my AEM pads (front and rear). The holes only help with gassing but it could have contributed to faster wear if they didn't come from a reputable company.
Autocross Help Page
Buy my Civic parts!
Old 04-29-2002, 01:46 PM
igo4bmx's Avatar
Banned
IMO brembo doesn't sound generic now does it?? heh heh
Old 04-29-2002, 03:39 PM
piscorpio piscorpio is offline
Send a message via AIM to piscorpio
Did you ever check to see if something was wrong with your brakes? That seems wierd for those to wear down so fast, especially given CivicSiRacer's input. What were you doing, just hammering on your brakes at every stoplight, just to test them out?
Im just curious as to why this happened to you, I was thinking about getting some AEM pads myself.
Old 04-29-2002, 08:48 PM
igo4bmx's Avatar
Banned
sad part is.. usually i don't drive crazy.
Old 04-29-2002, 08:55 PM
So whats the deal here? The rotors, the pads, maybe they were put in wrong, or was it something else? Anyone else have this problem with AEM pads?
Old 04-29-2002, 09:02 PM
igo4bmx's Avatar
Banned
the only other thing i could think of was the fact civicsiracer has four disk brakes.
the amount of force need to stop the car compared to mine will be evenly distributed across four pads as opposed to my two pads. therefore with my lousy drums, the brake pads will require a higher friction coefficient to stop my car thus wearing out faster
Old 04-30-2002, 01:00 AM
madtownhonda's Avatar
madtownhonda madtownhonda is offline
Send a message via AIM to madtownhonda
OEM pads work great...I've used all the "high performance" pads and OEM are not any, if at all, worse.
96 EX DOHC VTEC
Old 04-30-2002, 07:11 AM
Civic Mod
Actually the rear drums should have enough stopping power to help your front brakes. I'm thinking maybe something wasn't bleed properly like air in the lines. If you had no air in the lines for the fronts and air in the lines for the rears that means the front brakes would have to work harder to slow you down.
Did you properly break in your pads too? Did you replace front and rear brakes at the same time or only the fronts?
Autocross Help Page
Buy my Civic parts!
Old 04-30-2002, 07:16 AM
igo4bmx's Avatar
Banned
i only replaced my fronts.
that could be the problem
