Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 07-27-2005, 02:43 PM
MontanaMan328 MontanaMan328 is offline
Oil Cap Stuck
Just yesterday, I was trying to remove the oil cap on the engine (I was being curious, and in case I ever needed to add oil) and I couldn't. It turns a once or twice, and then stops. I cannot unscrew it completely. I've never seen this before on any vehicle I've owned.
Any ideas?
Old 07-27-2005, 04:46 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Oil Cap Stuck
Try turning it as far as you can and then pull straight out. Some of the newer ones are not screw in but have a notch that must be aligned and then pulled out.
Old 07-27-2005, 04:56 PM
Re: Re: Oil Cap Stuck
Ah, OK. I'll give that a shot & let you know. Thanks for your input!
Old 07-29-2005, 09:04 AM
1999montana's Avatar
1999montana 1999montana is offline
Re: Re: Re: Oil Cap Stuck
Mine started doing this about two years ago.
Seems the cap expands or the throat on the filler contracts; - take you pick!
I filed the edges of the cap to clean it up and greased it with white lube.
Seems work a bit better, but if I keep filing, it will turn into a toothpick!
Old 07-29-2005, 05:02 PM
Thanks for the info. It turns out you were exactly right!
