Old 07-27-2005, 12:34 PM
jerryls jerryls is offline
How do I read OBD-1 codes =16 pin connector
I've read all sorts of threads on this, but have not found an answer. I have a 94 3.8L VIN-L series. It has a 16 pin connector, but only pins 4,5,8,914 and 16 are used. I have an OBD-II reader that gives me an error when I try to scan the codes. Where can I get definition of this interim OBD operation
Thanks,
Old 07-27-2005, 09:34 PM
93buicklesabrelmtd's Avatar
93buicklesabrelmtd 93buicklesabrelmtd is offline
Re: How do I read OBD-1 codes =16 pin connector
Thanks,
This says its from 1985-1994
http://www.geocities.com/dann8785/se...nginesoon.html
This is what my 93 ODB1 looks like
http://autorepair.about.com/library/...l-dtcs-31a.htm
If you know what wire each #number stands for then I would..
Try to find the Ground teminal whatever # or letter it is.
Then try to find the Diagnostics terminal (same way), then jump those.
See what happens.... This may work...
Old 07-27-2005, 11:12 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
http://www.automotiveforums.com/vbul...d.php?t=307153
New Info: 1995 non-OBD-II 16-pin
Old 07-28-2005, 02:37 PM
Re: Re: How do I read OBD-1 codes =16 pin connector
Thanks, These are good sites, but both assume a 12 pin connector with a means of diagnostic pin to short. The 16 pin OBD-1 doesnt seem to allow any jumpering to have any lights blink.
I think I would have to read the serial data line.
Old 07-28-2005, 02:44 PM
Originally Posted by HotZ28
Thanks,
I read through this site and see the pin definitions of the 16 pin 94 Lesabre version. I think I can write a simple program to read the serial bits into a laptop. I dont know if it's worth trying to decipher it without some definition of what's transmitted. There may be all sorts of preamble bytes transmitted prior to the codes. If GM lists it somewhere, then I would write the program and put it on this forum.
Old 07-28-2005, 03:16 PM
padriver padriver is offline
Re: Re: Re: How do I read OBD-1 codes =16 pin connector
Thanks,
Here's some information that should help you:
http://pweb.de.uu.net/pr-meyer.h/bin...LDLstreams.zip
The archive contains lots of data stream formats and protocols. For your car, check out data stream A221 specification.
Old 07-28-2005, 03:57 PM
HotZ28's Avatar
AF Moderator Elite
In 1995 GM changed to OBD 1.5. Some late 1994 models are also OBD 1.5. For these (OBD 1.5, 16 pin ALDL) short terminals 5 & 6.
Turn key on, but do not start engine. Find and Short terminals with a paper clip. The check engine light will begin to flash. The ECM (computer) will display a "code 12" by flashing the "service engine soon" light, indicating that the system is operating. A code 12 is simply one flash, followed by a brief pause, then two flashes in quick succession. This code will be flashed 3 times. If no other codes are stored, code 12 will flash until the diagnostic terminal ground is removed. After flashing code 12 3 times, the ECM will display any stored trouble codes. Each code will be flashed 3 times, then code 12 will be flashed again, indicating that the display of any stored trouble codes has been completed.
Old 07-31-2005, 02:49 PM
amplifier28 amplifier28 is offline
Hey "hotz28"
How can we short terminals 5 & 6 if terminal 6 does not exist and is not used in a 1995 Buick LaSabre?
Old 07-31-2005, 07:43 PM
HotZ28's Avatar
AF Moderator Elite
OK, so you have the bastard. Short pins 4&9 and see what happens.
Old 08-01-2005, 11:32 AM
Re: Re: Re: Re: How do I read OBD-1 codes =16 pin connector
It looks like there are modes that the ECM can be put in. I don't see an input pin for the scanner to select a mode. Possibly the serial pin(9) is bidirectional? Else the ECM just spits out all the information in a loop? Do you know where this may be further defined?
Thanks
Old 08-01-2005, 11:54 AM
Yes, there are different operating modes. Pin 9 is indeed bidirectional and used for getting the data as well as switching between modes.
Here are some links to schematics of interfaces:
http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm
http://pweb.de.uu.net/pr-meyer.h/aldl.htm
If you google for ALDL 8192 you should find quite a few sites with further information. Some time ago, I started a similar project, but I haven't finished it yet because my car started to give me trouble and I needed quick diagnosis, so I decided to buy a scan tool.
Old 08-01-2005, 12:57 PM
Thanks,
This is all very good information. I looks like a lot of work has been done before on this. It's alot of effort to read an interim code. The OBD-II readers can be purchased for <$100.00 and work on all cars after 96, so maybe I'll bite the bullit and just take the car to a dealer, and have them read the codes.
Old 08-01-2005, 03:52 PM
HotZ28's Avatar
AF Moderator Elite
Take it Auto Zone and see if they can do it. If not Auto Zone, surely some of the auto parts stores can scan it for free!! My scanner will do it!!
Old 08-01-2005, 06:19 PM
mcqueary mcqueary is offline
Hi HotZ28. So what kind of scanner do you have that reads OBD-I codes from the 16-pin OBD-II connector on a 1995 Buick Lesabre? I have tried two different generic OBD-II scanners, my own and one at a shop, and they both report bad data link. Are you using the GM Tech I or Tech II scanner? Thanks, Tom.
Old 08-01-2005, 08:57 PM
HotZ28's Avatar
AF Moderator Elite
I still have an old Snap-On MT-2500 scanner that I bought used several years ago. I also had to get the OBD II connector with a special key for OBD I readouts. I forgot the key number, but a Snap-On dealer should have the info needed.
I currently use the Genisys Kit with Pathfinder 2003, Asian Import 2003 and ABS/Airbag 2002 Software.
