Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-27-2005, 10:42 AM
RodCar RodCar is offline
78 caprice needs help!
Hi, I have a 78 caprice 350 SBC is the mexican made one, also I am in Mexico, I have invested on some stuff and I really expect a great change, but besides more gas consumption car is the same, can somebody help me and send me some tips to make my invest work?
I have installed. Edelbrock 1406 carb, moroso carb gasket 1", msd 9 mm cables, dui hei coli high voltage, edelbrock performer intake, msd 6a, and stock spark plugs at .055", 105 amp alternator.
As far as I know all of these changes should be doing tire burned, I am a little dissaponted, maybe I do not know the right specs to squeeze all the equipment in my car, any help is welcome I want to be the fast car down here!
Old 07-27-2005, 05:03 PM
jeff99212's Avatar
jeff99212 jeff99212 is offline
Re: 78 caprice needs help!
I had the same problem with my 78 caprice where there was a huge loss of power, in my case it was the catalytic with 3 pounds of backpressure, tons of unneeded emission crap was removed, the tranny vaccum modulator was clogged, and the distributor was 180 degrees off- To this day I'm surprised the car even ran, now with all that taken care of it's quite difficult not to spin the tires everywhere I go. Hopefully this may give you an idea for some things to check, by the way, I am still using the stock engine and carb. Best of luck to ya and I hope it's something simple.
Old 07-28-2005, 09:33 AM
Thanks Jeff, my car does not uses cat. conv. and distributor was changed to a Pertronix flame thrower, I really do not know what is happening with it, I appreciate the help.
Old 08-01-2005, 08:58 AM
I forgot to mention that I have 2 flowmasters and 2 2 inches exhaust pipes.
Old 08-08-2005, 08:33 AM
Please help!
Also if anybody know how to wire the wipers? I bought a timed switch and motor from a 84 I supose that an extra wire should be conected, does anybody know how?
Thanks.
Old 08-19-2005, 01:18 PM
Ok, I have retuned all the car and is still not burning tires, I will try to close spark gaps to .045" does anyone knows something about the crane hifire 6A I am thinking on replace the msd for this one, also I really will appreciate help on the wipers issue.
Thanks.
