Old 07-26-2005, 11:18 PM
p8ntman p8ntman is offline
leaking transmission
I have a 97 Blazer with intermitant transmission leak. It will only leak some times. the fluid is coming from the upper right side of the transmission, not sure exactly ware its coming from. dosn't look like its from the lines.
it happens on the freeway usualy when the ac is on. has never leaked when pulling 19ft boat. I have a large trans cooler with fan. the fluid looks clear and red, not burnt at all. thanks for any help.
Old 07-26-2005, 11:29 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: leaking transmission
Sounds like your tranny fluid may be overheating and blowing out the vent.
That, or your servo is leaking.
Have a shop check it out. Also, have you ever serviced your transmission?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-27-2005, 06:41 AM
leak
It was serviced 20K ago. I droped the pan yesterday to service again, because of pulling the boat. the fluid looks like it just came from the bottle. whare is the servo located? is this somthing I could change?
also, 3 months ago went on 1200 mile trip from MI to SD with lots of hills and didnt use one drop. on the way home used about 1 qt.
Old 07-27-2005, 11:15 AM
BlazerLT's Avatar
AF -Advisor
You sure the tranny wasn't overfilled?
Old 07-27-2005, 09:56 PM
leak
I found whare the leak is coming from. There is a rubber hose zip tied to the transmission filler tube and it goes down to the top of the transfer case. it looks like a vent. the fluid is running down the hose and firewall to the top of the trans.
Old 07-28-2005, 12:59 AM
BlazerLT's Avatar
AF -Advisor
Your transfer case is probably overfilled.
Often happens when the transfer case/tranny seal is leaking.
Take the top fill plug out of the transfer case on level ground and see if any fluid comes out.
Old 09-07-2005, 06:52 AM
awc109 awc109 is offline
I have an issue when mine only leaks when I use 4wd, and unfortunatly it poors onto the exhaust pipe. I haven't been able to pin point where it is coming from though.
Old 09-07-2005, 10:53 AM
BlazerLT's Avatar
AF -Advisor
Probably from an overfilled transfer case.
On level ground open the top fill hole on the transfer case and see if any fluid comes out.
Old 09-07-2005, 04:10 PM
drdd's Avatar
drdd drdd is offline
Re: Re: leaking transmission
serious question - not to sound sarcastic but, how is it possible to overfill a transfer case? doesn't it just come out the fill hole when it is just past its proper level?
Old 09-07-2005, 08:16 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: leaking transmission
There are two plugged holes, one for draining, one for filling.
If it is overfilled, fluid will come out the top fill plug when you remove it.
The fluid level full is supposed to be only to the bottom of the top fill plug.
Old 09-07-2005, 08:22 PM
drdd's Avatar
Re: Re: Re: Re: leaking transmission
Yes I know. I just recently changed my tcase fluid. I can understand how it could be underfilled but is it not physically impossible to fill past the top fill plug (overfill)?
you'd have to try to overfill it without the fluid coming out the hole and then somehow screw in the plug before it came out of the hole. See what I'm saying? ... unless the truck is on a inclined hill or something strange like that, it would be impossible to overfill ... it would just come out top hole ...
again, not trying to be sarcastic. Is there any other way that a tcase might get overfilled ?
Old 09-07-2005, 09:04 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Re: Re: leaking transmission
Yes, the cause of the overfilling is from tranny fluid leaking from the transmission through the tranny/transfer case seal like it is known to do.
Old 09-07-2005, 09:10 PM
drdd's Avatar
Re: Re: Re: Re: Re: Re: leaking transmission
got it! Thanks!
