Old 07-26-2005, 08:38 PM
fierangero's Avatar
fierangero fierangero is offline
Send a message via AIM to fierangero Send a message via MSN to fierangero Send a message via Yahoo to fierangero
Unhappy Failed Smog
Hello, tried to get my car smogged yesterday (california, btw) and much to my chagrin it failed. running too rich. heres the scores
for the HC/CO/NO the scores are measure/limit
15 mph:
RPM: 1844
%CO2: 13.0
%O2: 0.6
HC (PPM): 234/147
CO (%): 2.35/0.88
NO (PPM): 1237/889
FAIL
25 mph:
RPM: 2865
%CO2: 13.3
%O2: 0.1
HC: 173/122
CO: 2.43/0.78 (Gross Polluter limit is 2.28 )
NO: 636/828 <-pass!
Fail - GP due to Carbon Monoxide
engine light comes on under heavy accel at freeway speeds occasionally
had codes scanned
code 1: O2 sensor
Code 16: fuel injectors
had valves adjusted after codes came out, killed codes, light still comes on
im thinking its the o2 sensor, i probably fouled it when i had my blown head gasket. fuel injectors seem fine, great throttle response.
any input/suggestions would be appreciated
Rest In Peace, Rich Hall
my baby: 1986 Fiero GT: v6, automatic, 2.8L, 2.02/1.60 heads, Crane Performance Cam, Ported/polished exhaust manifolds, taylor plug wires, low temp thermostat and fan switch. WCF catback exhaust
She's done!
Old 07-26-2005, 09:33 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Failed Smog
Its running rich, and your getting an injector code, but you think there fine..... I tell you man, they dont make them like you offen.
Old 07-26-2005, 11:11 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
Re: Failed Smog
code 1 means bad o2 sensor.. so try replacing that. when code 1 turns on i think it tells the car to run really rich.
Old 07-27-2005, 08:22 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Failed Smog
Go to the auto parts store and buy a $17 oxygen sensor and hook it up tight (solder if possible) and cover up/protect all your extra wire. Check your fuel injectors to make sure they're not leaking. Reset the ECU. Go back to smog and pass...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 07-27-2005, 10:54 AM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
Re: Failed Smog
also... this may sound lame but i was running way to rich and besides doing a basic tune-up i put a little bottle of this stuff in my gas and drove it for 60 miles and it cut my numbers in half. It's called RxR (i think). On a web site people said it worked awesome so i figured what the heck, it's in a tiny red bottle next to the fuel injector cleaner crap in the autoparts stores. I bought mine at Autozone.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 07-27-2005, 12:40 PM
fierangero's Avatar
Re: Failed Smog
thanks guys, i'll replace the o2 sensor, and clean the fuel injection system, and hopefully that will fix it. if not, then its the injectors T_T
She's done!
