Old 07-26-2005, 08:12 PM
cnogood cnogood is offline
Send a message via AIM to cnogood Send a message via Yahoo to cnogood
when a/c is on car overheats
I have a 89 rs 2.8 engine my air works, but when I drive for bout a 1/2 hr or more it overheats. And when I stop I hear anti freeze bubbling hot in the over flow. Anyone have a solution. My fan comes on. So dats not the problem. Could it be to much anti freeze
Old 07-26-2005, 08:59 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Re: when a/c is on car overheats
check the simple stuff, radiator working, themometer working, fans working etc.
Does it ONLY over heat when you have the A/C on and doesn't overheat any other time?
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 07-26-2005, 09:07 PM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
my 92 does the same thing, about a half hour with the a/c on and the temp guage starts rising. turn the ac off and it goes back down to normal. i don't know if this is normal or not
Old 07-26-2005, 10:47 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
using the AC should not cause it to overheat, i would remove and test your thermostat in a pot of boiling water and thermometer.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-27-2005, 11:28 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
the A/C does work the engine more when it is on. the temp will rise a little more. but what temp is your car at when you say it is "overheating?"
if it really is overheating, only with the A/C on.... then have you checked to see if the fan turns on when the A/C is on? If not, then you could have a malfunctioning "Fan A/C pressure switch". it regulates when the fans turns on/off based off the A/C pressure. i don't know how the two are related nor why they make it work like this. nor do I know where the switch is located, but i have a hunch it's actually inside the compressor itself... hence there are 3-4 wires that connect to the compressor.
just a possiblity.This could be one of the few problems I would take to the dealership (hard to locate the cause). (that way if they don't find it the first time, you can complain and have free work done until it's fixed).
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 07-27-2005, 01:07 PM
But wut is causing the anti freeze to bubble and boil in the over flow
Old 07-27-2005, 01:43 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
too much water in the coolant. when it overheats it boils. Or your radiator cap isnt sealing properly. Or your engine is really friggin hot. Which like was said before...could be your thermostat....maybe some leaves in your front cooling ducts.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 07-27-2005, 06:21 PM
Car over heats w/ ac = you care doesn't think ac is a good idea, get one of those plug in fans
Be Warned....
XENO...
Xtreme
Emotional
Neurotic
Ominous
Old 07-27-2005, 06:44 PM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
Re: Re: when a/c is on car overheats
lol, i thought water was the coolant?
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
Old 07-27-2005, 06:45 PM
Originally Posted by Xenostalgia
Car over heats w/ ac = you are gay
wow, greatest helpful words ever! where would we be with out a post whore like you... lol
~Viper
=D thx
Be Warned....
XENO...
Xtreme
Emotional
Neurotic
Ominous
Old 07-27-2005, 06:48 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Lucky 89 isnt here to threaten you like he did me when I said something was gay, stopped THAT.
About the overheating, sounds like your thermostat. that's probably the problem.
Old 07-27-2005, 11:35 PM
89IROC&RS's Avatar
xeno has gotten a smack on the wrist and is changing the post, doing it again probly wouldnt be that smart....
Old 07-27-2005, 11:48 PM
stepho stepho is offline
Send a message via AIM to stepho Send a message via Yahoo to stepho
Re: Re: Re: when a/c is on car overheats
OH OH OH something I know a little bit about. You can use water as coolent it is supposed to be distilled water though (when I got my new radiator it said the warrenty is void if you use something other than anti-freeze or distilled water). It is best to run anti-freeze though. Anti-freeze is better because it has a higher boiling point than water.
There are two ways to keep water from boiling, keep it under 100 degrees C or keep it pressurized. Since the water is being run through your extremely hot engine keeping it cool is out of the question. There for you have to keep it under pressure. If you radiator cap is faulty or not attached properly it will cause pressure to escape which means the water will vaporize.
Originally Posted by sportlinetta
lol, u guys are dummmmmmmmmmmmb im 14 n i know more. i gotta 88 camaro.
would that mean get a new cylinder or plug???
Old 07-27-2005, 11:57 PM
89IROC&RS's Avatar
water is a better conductor of heat though, thats why you run a 50/50 blend, water cools, antifreeze does just that, keeps it from freezing, but it does sound like the radiator cap isnt doing its job correctly. should be a cheap fix or diagnostic test.
