Old 07-26-2005, 07:31 PM
Law_3KGT Law_3KGT is offline
resistors?
One of my buddies was telling me about a "50 cent resistor" that will add like 20 hp. I was reading about these and found out that you put them in your intake and it tells your computer that the air temp is like 30 something degrees. anyway i need to know if this is true and if it will mess up anything.
Old 07-26-2005, 08:19 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: resistors?
read the FAQ sticky thread.
here are some posts about those piece of crap resistors:
http://www.automotiveforums.com/vbul...light=resistor
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-26-2005, 11:47 PM
Igovert500's Avatar
blue + red light magnet
Re: resistors?
It's a POS if you pay $20 on ebay, and it's still a POS when you only pay 10 cents for it at radioshack. Save your money. There are no gains to be had.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-27-2005, 08:34 PM
Hotshot8792 Hotshot8792 is offline
yea, only thing it does is make your car run leaner since cooler air tells the ECU not to dump as much fuel in. Definitely not a good thing to do on a turbo car, and still wouldnt recommend it on an N/A car. If you want to lean it out, do it properly with an S-AFC so you can control how much you lean it out instead of a resistor guessing for you.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 07-27-2005, 10:44 PM
Igovert500's Avatar
Re: resistors?
Wouldn't recognition of cooler air tell the ECU to dump in MORE fuel, to prevent lean conditions, ultimately causing the car to run richer? Or am I too tired to think straight?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-27-2005, 11:14 PM
Re: Re: resistors?
we're all tired but no, it adds more fuel as the temperatures rise because more fuel cools down the engine temps. When the temp falls, your engine can handle a little bit more so it takes away a little bit of fuel. Main reason i know this was it was part of my predetonation problems with the MAF-Translator. The MAFT, along with other airflow sensors such as the arc 2 do not include a temperature sensor or a barometric pressure sensor, so the ECU thinks its the same temperature all the time. When the temperature increased, my engine predetonated because it couldnt overcompensate for the increase in temps, which is why if you have one of these, either you need to tune it be what time of year it is, or tune it in the hot weather and run a little bit rich in the cooler weather.
Old 07-28-2005, 03:07 AM
Linebckr49's Avatar
Re: Re: Re: resistors?
interesting. nice piece of info to have there. so have you solved your problem by just tuning it according to the weather/seasons? or haven't you gone with a new setup?
93 3000GT base
